What is going on? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-18-2011, 05:03 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
What is going on?
Last week I took the truck in for what appeared to be a brake fluid leak.
After looking it over they determined it was not brake fluid. They emailed "Engineering" and they had no idea what it could have been and stated there are no fluids or oil inside the cab. There fix was to clean it up and see if it comes back.
Just wondering if anyone else had this happen to them?
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #2 of 12 Old 05-18-2011, 05:26 AM
Anth's Avatar
I thought I read about this somewhere, and it was just that they over greased the brake pedal.
Anth is offline
post #3 of 12 Old 05-18-2011, 05:31 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
That is what the dealership is thinking, something during the assembly more than likely.
Previously Owned
TW720HVY is offline
post #4 of 12 Old 05-18-2011, 05:32 AM
justinlogue5_0's Avatar
I know some grease will run like an oil when it gets hot (from heater etc...). Can you see any signs of some thing that looks like it had heavy oil on it? Maybe steering column or some thing?
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #5 of 12 Old 05-18-2011, 05:43 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
I looked and it appeared there was oil on the bracket of the brake peddle and push rod.
Previously Owned
TW720HVY is offline
post #6 of 12 Old 05-18-2011, 05:45 AM
mor4wd's Avatar
I've heard they over-greased the sliding pedal assembly and it drips every now and then.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #7 of 12 Old 05-18-2011, 05:47 AM
I hate to sat it but you might just have to clean every thing real good and watch it. It could be a seap that finally built up enough on that bracket to drip. If you clean it real good and in a day or two the bracket/pedal is wet again then I would guess the seal is going bad on the back of the brake chamber(which on ours I believe is the Hydroboost)
It never ends!
post #8 of 12 Old 05-18-2011, 11:03 AM
Yep I have noticed some leaking on my floor too. I wasn't worried about it but I will ask about it next time I take my truck in.
2011 F-250 XLT Crew Cab 4x4 - Sold
Hideaway Gooseneck Hitch to pull my Longhorns!
Access TonnoSport Removable Bed Cover
2006 F-250 XLT Crew Cab 4x4 - Traded
Banks 6 Gun Programmer
4" Turbo back exhaust
EGR Delete
jflow730 is offline
post #9 of 12 Old 05-18-2011, 03:34 PM
Yeap Over Greased Read about this a Few Times!
I Just Re-greased my trailer bearings,and Installed Buddy bearings on all four,I noticed that there was a Blueish Liquid leaking out the Buddy bearing from the grease,i'm sure this is the same thing the brake Pedal is doing....
The Grease i'm usen is Good stuff so Maybe thats a Good sign when it Leaks the liquid...
Lead Foot is offline
post #10 of 12 Old 05-19-2011, 09:03 PM
67powerstroke's Avatar
Yeah my emergency brake dripped grease once. Cleaned it up and it's been fine. Lucky it didn't drip on your carpet.
2011 F250 6.7L
67powerstroke is offline
