No oil pressure gauge?! C'mon... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-04-2011, 11:26 AM Thread Starter
rascal's Avatar
Did Ford really not put an oil pressure gauge in the truck.
Someone please tell me I'm wrong, call me an idiot, and tell me where it is.
Thanks,
Rascal
rascal is offline
post #2 of 7 Old 05-04-2011, 11:59 AM
matty21's Avatar
It's right behind the rear right tire, sit there till your dizzy Im sure you will find it
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 7 Old 05-04-2011, 12:53 PM Thread Starter
rascal's Avatar
Why didn't I think of that? Duh!
rascal is offline
post #4 of 7 Old 05-04-2011, 04:04 PM
matty21's Avatar
haha yeah
and id like a battery gauge too
another reason to get H&S tuner
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #5 of 7 Old 05-05-2011, 12:14 AM
DavidPhillips's Avatar
The 6.4 did not have one either.
If you had a gauge what would it read? Would it tell you anything you need to know? Would you pull over at some point and change the oil or rebuild the motor?
I'm just curious.
Nothing against gauges but its not really a necessary gauge. It is not a replacement for checking the oil.
All my touring photos. (except the two massive trips in 2011-soon to be posted eventually)
-david
/ 2011 F250 4x2 Crew Cab /
Replaced "The Beast" 6.4L with 75,000 miles. Hated to see it go.
DavidPhillips is offline
post #6 of 7 Old 05-05-2011, 06:35 AM Thread Starter
rascal's Avatar
No, I agree it is not a replacement for checking the oil. However, when I change the oil in my truck I like to be able to monitor the pressure on startup.
I also like to have it as just another "feel good" gauge. I have had one in every other truck I had and I guess I am just disappointed to no longer have one. I would always just glance at it when I was driving down the road.
I just dont think it would have killed Fords profit margins to add another reading. Heck, they tell us oil temp...
rascal is offline
post #7 of 7 Old 05-05-2011, 10:22 AM
I considered three gauges on the 6.4. There is room for three maybe four on the pillar. I never got around to it but was considering EGT, rear diff temp, & lift pump fuel pressure.
Amp gauge would be great. See how the camper battery is charging.
My old Chevy 6.5 I added those as well as trans temp and oil temp.
EGT is the most important as you can use it to adjust your driving for best overall results. Rear diff temp is handy but probably not necessary if your not pushing the weight limit. The old Chevy was a 1500 so I was pushing the tow rating way past the limit. When the diff got hot I let it cool off. Added a cover and synthetic oil and it dropped considerably. Didn't need the temp gauge after that but it did the job. Not really sure about the fuel pressure on this but on most older diesels it was very important. The truck would seem to be fine until the injection pump went out. Hopefully on these the computer would say something. The fuel pressure is great if you modify the trucks fuel delivery to see if you need a better pump.
One might go with a dash daq and have it all if you don't mind the digital display. I prefer actual gauges.
I would expect it to peg out when cold. Slowly drop as the oil warms up and settle at some point. Slight fluctuations with load and rpm. Had one of those plastic oil lines break inside a car and it made a heck of a mess. It never did much other than that. An electronic gauge would be much better. Less chance of oil leaking somewhere resulting in no oil in the motor.
I guess the theory is that you can't do anything about it so why look at it. Temp is more useful than pressure. You can always adjust what your doing or stop and let it cool off. When oil pressure drops your done. Pull over and call a tow truck. A light coming on can do that just as well.
-david
