Cetane Boost Question - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-27-2011, 02:27 PM Thread Starter
I've got a 2011 F-350 Dually, 6.7, just finished changing the oil today. While checking out at Auto Skills Center, guy at the counter suggested to me that I should use Diesel Kleen + Cetane Boost in my truck. Told me that it is good for injectors, etc. I looked in the Truck owners manual and read that fuel additives should not be necessary as long as I'm fueling with ultra low sulfer diesel. Guy at the counter (promises he wasn't trying to sell me anything--this skills center is on a military installation) claimed that this additive gave him more power, better fuel mileage, easier starting in his '07 F250. I had a Cummins before my current rig, have 22,000 on current rig and never have ever used any fuel additives. Not sure what to think. I'm sure this stuff is fine for engines that are a little older, but not sure if there's any data out there regarding performance increase/decrease in the new 6.7l. Any thoughts, experience, successes, and/or advice? I'm getting ready to move this Saturday from San Diego to Detroit and am willing to try, but don't want to take any unnecessary risks, so any insights are much appreciated. Thanks!
Grizzly 16
2011 F350 Lariat DRW
2009 35' Montana Mountaineer
2009 Honda Foreman
2005 Honda Rancher
2008 Honda TRX 90
2006 Honda TRX 90
2005 Yamaha Raptor 50
2008 Yamaha VX Deluxe Waverunner
2003 Yamaha FX 140 Waverunner
Active Duty U.S. Army
Grizzly16 is offline
post #2 of 15 Old 04-27-2011, 04:51 PM
Mtn Trucker's Avatar
I wouldn't since with todays complex emissions systems you're liable to gum something up or wreck a DPF filter. If that happens, and they can find evidence of the additives, you'll be footing the bill. Not to mention that most of those additives are just snake oil anyways and really don't do anything.
I do put a small dose of Siloo diesel fuel conditioner in once or twice ayear just to catch any moisture that may have accumulated in the tank.
Mtn Trucker is offline
post #3 of 15 Old 04-27-2011, 05:02 PM
I use the cetane booster from ford and can tell a difference in mileage.I looked at different brands and they called for 8 ozs for 25 gallons of fuel.The ford brand calls for 4 ozs for 25 gallons.
gr8white is offline
post #4 of 15 Old 04-27-2011, 05:08 PM
studdgage's Avatar
well i dont have a 2011 but the diesel kleen works well in my 7.3 it does make it start easier specially in the cold and i pick up about .75 miles to the gallon with it. Also suppose to clean the injectors too. One thing i really like about it if you are in the colder areas your diesel wont gel up with it in it.
Some people are like slinkies they are completely useless but they still bring a smile to your face when you push them down a set of stairs
studdgage is offline
post #5 of 15 Old 04-27-2011, 05:16 PM
I had a 5.9 Cummins prior to the 6.7. Tried different fuel additives several times with that engine and never saw any gains. So haven't really considered using it in the 6.7.
2011 PSD KR
Lurker is offline
post #6 of 15 Old 04-27-2011, 07:39 PM
I use it in mine, mainly to add a little lubrication back, they say the ultra low sulfur fuel is pretty dry and is hell on fuel pumps etc...?? who knows if thats true manuel says its ok to use so I do
jbm49u is offline
post #7 of 15 Old 04-27-2011, 08:37 PM
Keep a little bio-diesel in the tank. Great for lubrication in fuel components and is a great cleaner. Just be sure to have new fuel filters on hand./
DrLo is offline
post #8 of 15 Old 04-30-2011, 06:08 PM
check u'r owners book...says in diesel supplement that additives are suggested and recommended...and ford sells it under the motorcraft label.
dc.snowball is offline
post #9 of 15 Old 05-04-2011, 01:48 PM
mor4wd's Avatar
I run Power Services white bottle. Never really noticed much of a difference until last weekend pulling 18k from CA to UT. Alternated using the additive every other tank and noticed pretty much exactly 1 mpg increase with the additive, but for the cost of the stuff, it's not worth it. I'll add it when it gets cold to prevent gelling.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #10 of 15 Old 05-06-2011, 05:13 PM
hay now..mr. mor4wd...we use a product named stanadyne cetane boost.. works well, but notice little with mph. our latest is '11f-350//3.55 gears...and as i have said before the best!!!!!!! i can get is 17-18...foot out-down hill-tail wind..have a good day...
