Is it just me, or does this seem backwards? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-26-2011, 03:23 PM Thread Starter
The engine designers confuse me. So the diesels come with intercoolers to condense air to put more oxygen in the cylinder. Awesome! But then they put this big, heavy, ugly egr on the engine. Now correct me if im wrong but the egr's only purpose is to circulate exhaust back throught the intake. This is to reduce the oxygen content by taking up space that would otherwise be filled with oxygen rich air. With less oxygen the cylinder temp is lowered to avoid producing NOx (which happens around 1,250 F) to pass emissions.
Now tell me doesnt this sound counter productive??? I have a simple solution, for roughly the same cost manufacturers could install a factory water- methanol injection system that would do the same thing, increase power, and not clog your intake with soot.
'65 F100 Reg Cab SB
'96 F150 XL Reg Cab LB 4.9L I6 5 speed
Work truck- '99 F-550 wrecker 7.3L ZF6
SOLD- 2001 Dodge 3500 DRW 4x4 QCLB 5.9
Semper Fi
Americanmade89 is offline
post #2 of 18 Old 04-26-2011, 03:32 PM
Quoted: 3 Post(s)
off topic but i saw in your sig 65 f100 diesel swap, got any pics?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 18 Old 04-26-2011, 04:01 PM
Americanmade89,you should pick up the May 2011 Diesel power mag it has a section in it that says "Water injection VS,Intercooler" Both can reduce EGT,But which is right for you?
Man ,they show one Pic,where they spray water Directly into the Turbocharger, :~0 it says this can lead to pooling and possible corrosion,so it's mostly reserved for competition -only vehicles...pretty cool I think :~)
That Mag also has a section on the 6.7 Getting the Full deletes, they say that EGR weighed 25 Lbs and really exposed the passengers side vaule cover when they removed it...
its a good read :~)
Lead Foot is offline
post #4 of 18 Old 04-26-2011, 04:31 PM
CowboyCody's Avatar
when it has to do with emmissions regulations all common sence goes out the window! its kinda like burning fuel to clean out the DPF or the cash for clunkers program. if it has the label "green" on it, it probly dosent make common sence.
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #5 of 18 Old 04-26-2011, 04:55 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
The EGR's job is not to re-route exhaust gases into the intake. The EGR's job is to reduce emissions. Routing exhaust gases into the intake is how it accomplishes that. I'm sure when/if the auto industry finds a more efficient way to reduce emissions that they will give it a go!
dazdillenger is offline
post #6 of 18 Old 04-26-2011, 05:19 PM Thread Starter
No sorry man, its back in Illinois and I'm in California till December on active duty. Once December rolls around and I EAS I'll be sure to post some pics of it. But to fill you in, I'm currently doin a frame off resto on it and it will be recieving a 12v cummins 6bt with a zf 6 speed manual. Debating on hydralic steering, or leavin it manual
'65 F100 Reg Cab SB
Semper Fi
post #7 of 18 Old 04-26-2011, 05:26 PM
The turbo and CAC isn't for extra or more oxygen into the chamber for combustion. The turbo and CAC is to put more "air" into the chamber for cooling and a cleaner combustion. The EGR idea isn't a positive thing for engineers, it's just one way of meeting EPA requirements. They didn't add EGR for power or efficiency.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #8 of 18 Old 04-26-2011, 05:35 PM Thread Starter
Lead Foot, Definatly a great read, and actually what started my rant! I love Diesel Power
Totally agree with you, I hope here in a couple years they figure out the learning curve just like gas motors had to back in the '70s. But really the tech is already there with PCCI, and individual hydralicaly operated valves, cummins even has a concept to recapture lost heat energy. Thermal effeciency will be the key to future engine designs
I understand EGR's job is NOx reduction, but I'm just saying I think water meth could do it more efficiently for roughly the same cost to the manufaturer. All egr does is help reduce cylinder temp, which is exactly what water meth does without all the soot in your intake
'65 F100 Reg Cab SB
Semper Fi
post #9 of 18 Old 04-26-2011, 05:51 PM
mor4wd's Avatar
EGR doesn't reduce cylinder temp, it actually raises it by recirculating spent gases. It's all there to insure a cleaner burning exhaust by double burning partial exhaust gas.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #10 of 18 Old 04-26-2011, 05:56 PM
EGR does indeed lower cylinder temps....that is the whole point of it. Lower cylinder temps, lower NOX....
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
