Bang Bang rattle rattle Bang Bang - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-14-2011, 10:11 PM Thread Starter
4x4ord's Avatar
Quoted: 3 Post(s)
My truck is making a clanging noise at about 45 mph when slight throttle is being applied. I have it booked in to be looked at on Monday but wondering if anyone has experienced this. My imagination is telling me that it might be loose bolts securing the torque converter to the flywheel or possibly something like the waste gate on the turbo opening and closing very rapidly? Anyone experienced anything like this?
4x4ord is offline
post #2 of 20 Old 04-15-2011, 08:45 AM
Porthole's Avatar
With or without your load?
I notice mine at times of light throttle almost sounds as if the pilot injection is turning on and off.
Thanks,
Duane
First ever blue oval........
2011 F-350 DRW White Tri-coat
2010 3010 Cyclone Toy Hauler
Porthole is offline
post #3 of 20 Old 04-15-2011, 02:14 PM Thread Starter
4x4ord's Avatar
Quoted: 3 Post(s)
I haven't noticed it without a load but haven't hardly driven it unloaded. This is a real banging kind of rattle. I initially thought it was the lid on the gooseneck trailer's tool box rattling but later realized it is definitely coming from the truck. When the rattling starts I can give it either more or less throttle and the noise stops.
4x4ord is offline
post #4 of 20 Old 04-15-2011, 08:49 PM
cjf250sd11's Avatar
Quoted: 2 Post(s)
http://www.powerstroke.org/forum/6-7...ing-noise.html
Sounds familiar.^^
2014 F250 4x4 Platinum, Black Tuxedo Carli Commuter Fox 2.0 & Steering Damp, PP 4-link, Fuel Maverick 20x10 - 5" BS, Toyo Open Cntry AT II 35x12.50, Recon LED Smoked Tails, 3rd Brake, Cab & Mirror Lights
SOLD 2011 Super Duty F250 6.7L - Lariat Ultimate 4x4, Black Tuxedo, Icon 2.5" Lift, Bilstein 5100's, 35x12.50 Pro Comp Xtreme Terrain on 20x9 BMF Novakane 8's.
cjf250sd11 is offline
post #5 of 20 Old 04-15-2011, 09:01 PM
2000 f-250 7.3
GotDiesel85's Avatar
Send a message via Yahoo to GotDiesel85
yes driveline, agree. check out my gallery to see what happens if you ignore it while hauling heavy
DerekBob 2000 f250SD,
apr studs and mains,
FRx, HPx, 38r,
SP boost fooler, 6637, zoodad
HD clutch,
Bigger stix and nozzles, airdogII,
Terminator T-500 HPOP, Snow stageII,
PHP FU2, 4"tb 6"tip,
ISSPRO's(boost, pyro),
fog lights, bedliner,
4" block kit, 315/75R16 General A/Ts
GotDiesel85 is offline
post #6 of 20 Old 04-18-2011, 07:42 PM Thread Starter
4x4ord's Avatar
Quoted: 3 Post(s)
I brought the truck in today and they were able to immediately diagnose the problem. The said it is turbo stall. The turbo is stalling out due to the back pressure equalling the boost pressure. ( I suspect the actual noise is the waste gate chattering?) They told me I need to manually downshift the transmission when that happens. So I have 3200 miles on the truck and it has gone into the shop twice - first time for check engine light and the dealer says the truck isn't designed to pull a 19000 lb trailer. Second time to resolve the clanging issue and they tell me I need to manually shift my automatic transmission. Sounds to me like I need to trade it in on a Duramax.
4x4ord is offline
post #7 of 20 Old 04-18-2011, 08:04 PM
richc22a's Avatar
I brought the truck in today and they were able to immediately diagnose the problem. The said it is turbo stall. The turbo is stalling out due to the back pressure equalling the boost pressure. They told me I need to manually downshift the transmission when that happens. So I have 3200 miles on the truck and it has gone into the shop twice - first time for check engine light and the dealer says the truck isn't designed to pull a 19000 lb trailer. Second time to resolve the clanging issue and they tell me I need to manually shift my automatic transmission. Sounds to me like I need to trade it in on a Duramax.
The Dealer you choose makes the difference. The dealer I use services a lot of oil rig equipment, no bull. Just gets the facts. Your Duromax dealer might be on the same par as your Ford dealer, in which case....
Find a Ford tech that knows his job, makes a difference...
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #8 of 20 Old 04-18-2011, 08:19 PM
You mean there is no fix for the turbo problem? That doesn't make sense. Did you decline a fix?
2012 F250 King Ranch Black Deleted
2013 BOSS 302
2007 GT500
2004 Cobra
2001 Lightning
PUMPED 101 is offline
post #9 of 20 Old 04-18-2011, 08:37 PM
2000 f-250 7.3
swap the stock compressor wheel with a wicked wheel and surge usually stops, you could also get a ported compressor housing and a bigger waste gate accuator
FRx, HPx, 38r,
HD clutch,
post #10 of 20 Old 04-18-2011, 08:48 PM
2000 f-250 7.3
on my last post, disregard the wicked wheel part until i find one lol, but ATS does make a nice compressor housing
FRx, HPx, 38r,
HD clutch,
