steering question? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-12-2011, 01:28 PM Thread Starter
steering question?
Would changing the gear box change the ratio of the steering wheel and the tires. It seems to take alot if turning the wheel to get the truck to turn a little. Im coming from a dodge that would turn on a dime, I know the turning radius is going to be bigger cause the truck is longer just takes alot of wheel for a little turn. Thanks
2011 F250 6.7 Lariat Ultimate FX4 CC Tuxedo Black Tan Bottom
stroke11 is offline
post #2 of 10 Old 04-12-2011, 07:32 PM
mor4wd's Avatar
Yes it would, but you'd be hard pressed to find a way to change ratios. Give it a bit, you'll get used to it. Whenever I hop in my bosses Dodge the steering just feels wrong to me, but that's because I'm used to my Ford.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 10 Old 04-13-2011, 05:30 AM
You will not get used to it very soon stroke11. The Ford steering is my biggest gripe too.
I last owned a Ford in 1975 and have been in many GM and Mopar since. Those brands have used variable ratio steering for decades and I do not understand why Ford doesn't??
The first thing I noticed when I test drove my Super Duty was I went real long on the corners and could not seem to crank the wheel enough. "You will get used to it" kept going thru my head. One year later, , , , I still have not got used to it. This thing will wear your a$$ out in close quarter parking lots. My past trucks were far better for tight areas.
Just turning a normal corner in the street requires an extra 80 - 90 degrees crank of the wheel. It is not a one handed manuver like before. If a vendor looking to make a lot of money on a good product is reading this, , sign me up right now for a replacement vari-ratio steering gear for my Super Duty. I would pay up to two grand and be happy to do it.
stroke11, if you are like me, you will soon find the Ford is a pretty good machine. My old D-Max would beat my new Ford in every catagory, pulling, fuel milage, driveability and so on but I still like this Ford best. I think it is the nicer, roomier cab and all the tech Ford has installed. It's too bad Ford has not figured out how to turn corners yet though. I would buy another Super Duty today if I needed one, , , , , but I will not race a D-Max with it.
Enjoy your new truck guy, and look for straight roads!!
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #4 of 10 Old 04-14-2011, 08:21 AM
ShirtaDay.com's Avatar
Quoted: 5 Post(s)
Ford steering is also one of my main complaints - I came from 3 Dodges. The steering there is much more sensitive or crisp. On the Ford, it feels like I have to turn the wheel 1/4 turn before the truck responds. On the Dodge, it was a 1/4" - made it much easier to drive with one hand.
I've been in a Ford since Nov. '10 and still haven't gotten fully used to it. The Ford is also much harder to keep straight when towing on a windy day.
'17 F-250 KR
ShirtaDay.com is offline
post #5 of 10 Old 04-14-2011, 09:08 AM Thread Starter
Yep I've had my truck since november also, some parking lots will just wear me out. Why can't we take something from all three brands and build one bad azz truck.
stroke11 is offline
post #6 of 10 Old 04-14-2011, 09:15 AM
mor4wd's Avatar
I'm not sure what you'd take off the GM, the new Ford 6R140 is better rated than the Allison 1000 and that's the only thing I could think of that might be better than the Ford.
mor4wd is offline
post #7 of 10 Old 04-14-2011, 09:48 AM
Quoted: 5 Post(s)
I have to agree. I'd personally like to combine the Ford/Dodge into one super truck. It'd mostly be Ford, with a larger cab (like the Megacab), some in bed & in-floor storage, more responsive steering, Cummins engine, and built-in file storage for the nav units.
Overall the Ford is a better truck and that's why I'm driving a Ford (despite my mainly Dodge history (they were all 1/2 tons though)).
'17 F-250 KR
post #8 of 10 Old 04-14-2011, 10:06 AM Thread Starter
The allison is what I had in mind. I've been having shift issues with mine since day one I do think its just a flash issue that I hope to have done at the oil change.
stroke11 is offline
post #9 of 10 Old 04-15-2011, 07:37 AM
Eaton 80 auto locker axle
Variable ratio steering gear
adjustable headlights (need to lower my Ford lights but can't find screws??)
switchable cargo lighting (so I can close the door)
BedRug liner
mowdoc is offline
post #10 of 10 Old 04-15-2011, 07:43 AM
mor4wd's Avatar
Why would you possibly want an auto locker. That's like trading your ARB air locker in for a crappy Detroit. Selectable is the only way to go which comes with the FX4 package.
Adjustable headlights, read the manual. Little knobby thing that points straight up on the back of the housing. Stick a philips screwdriver in there, clockwise goes up, counterclockwise goes down.
Turning the interior lights on manually with the dimmer switch turns on the cargo lamp.
There's an awful lot of people who don't read the manual. That's like getting a super computer and being content to just play old Atari games on it.
mor4wd is offline
