Problem With Trailer Brakes - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-05-2011, 11:29 AM Thread Starter
I recently bought a new 20' GN Lowboy trailer with brakes on one axle. My truck is the only truck I have been able to pull it with. I can turn my gain all the way up to 10 and activate my trailer brake fully and it does slow down a little, but I figured it should lock them up at 10 and it being empty? I don't know anything about the brakes on the trailer, but do you guys think it's the trailer or something in my controller? Like I said the trailer is brand new...but so is this truck.
2015 Lariat F350 FX4 CC/LB SRW 3.55's Ignot Silver Zone 4" Lift Nitto Trail Grapplers 295x65x20 UWS ToolBox
Robertc82 is offline
post #2 of 3 Old 04-05-2011, 01:00 PM
The trailer brake control module in your truck is designed to NOT lock up the brakes on the trailer.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #3 of 3 Old 04-05-2011, 01:24 PM
SuperCrutyPS's Avatar
Quoted: 304 Post(s)
Garage
You might need to jack up and pull the wheels/drums to check the shoes and magnets. Trailer brakes can be adjusted similarly to the old automotive drum brakes. They may be out of adjustment.
I don't know a whole lot about GN trailers, but only having brakes one on axle seems weird. Doesn't seem like that's enough braking.
While it is true controllers aren't designed to lock up the brakes, when you manually operate the controller you should feel a good pull.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
