engine oil - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-29-2011, 07:35 PM Thread Starter
engine oil
Was just wondering what engine oil everyone is using in their 6.7 and any pro's or con's would be great...thanks
31modified is offline
post #2 of 14 Old 03-30-2011, 06:02 AM
mor4wd's Avatar
There's been a ton of oil related threads on the forum. Everybody has their opinion. The ONLY important thing with oil is to change it and change it early. I'm not saying it's required to change it early, but it's some pretty cheap insurance. Check out some of Blackstone's newsletters, they do a good job of comparing different brands of oil, and have never seen a noticeable difference between any of the comparable brands.
My opinion is this:
Buy oil from a reputable manufacturer for a good price and change the oil in your 6.7 every 5,000 miles.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 14 Old 03-30-2011, 07:08 AM
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
I have seen a few places that have special diesel oil, i.e. Shell Rotella. Is there a difference compared to regular 10w30 oil?
Also, I have been thinking about going full synthetic abut have heard you need to let the rings settle using conventional oil, then go to a blend and then go to a full syn. Anyone have any thoughts on this?
Last, doesnt the new superduty tell you when to change the oil so you dont have to mess with it at 5k? I read that in the manual and wondered how that would work with a synthetic. How does the computer know that its syntehtic or not, I assume it doesnt and you would need some way to tell it was time to change the oil. Any thoughts on this would also be appreciated.
TX_TRU_STUD is offline
post #4 of 14 Old 03-30-2011, 07:28 AM
mor4wd's Avatar
Yes, you need to buy Diesel oil. It typically called Heavy Duty Oil. For instance; Walmart carries Rotella T conventional, synthetic blend and full synthetic, Delo 400, Mobil, Motorcraft, and their own brand. DO NOT USE REGULAR MOTOR OIL.
As far as synthetics go. I see no reason to waste money on them. Read the Blackstone reports. I would never trust my oil to go 15,000 or 20,000 miles on synthetic. Like I said earlier, changing your oil early every 5,000 miles is cheap, cheap insurance on a $15,000+ engine.
Your engine will tell you when to change the oil, but's I believe it's only based on mileage since reset.
There will be guys on here saying that they let their synthetics go for 20,000 + miles using Amsoil. I would never buy a used truck that the owner did that, no matter what. Having good oil change records is a good way to boost value on a truck when you go to sell it.
Oil breaks down over time and looses it's lubricity and protective qualities. Keep clean oil in it and your engine will thank you.
mor4wd is offline
post #5 of 14 Old 03-30-2011, 08:39 AM
Quoted: 52 Post(s)
Yea I read in the manual its based on all kids of different things (5 to 10 areas), not just reset mileage.
Thanks for the info.
post #6 of 14 Old 03-30-2011, 05:11 PM
twin200's Avatar
Probably going to go with full synthetic with this truck. With my 7.3's in the past I always used rotella 15w40 every 5000 like mor4wd said. I can't decide to put the truck on a routine or let the computer tell me.I think the computer is going to go farther than 5000 miles maybe 7500 miles,but if we change at 5000 we are assured its ok,but it will cost more.I think I'm too old school to let a computer tell me when to change the oil or just ignorant
2000 F-350 7.3 4wd cc,dually lariat
afe intake,programmer. rear airbags
2011 F350 6.7 cc,4wd shortbox lariat
Tinted windows Gray bedliner(diy)
Tool box Bull bar
Front aux lights Rear aux lights
Onboard air Train horns
Billet grille LED bed lights
Mike
twin200 is offline
post #7 of 14 Old 04-01-2011, 04:56 PM
4x4ord's Avatar
Quoted: 3 Post(s)
I don't let the computer tell me either - I just don't change it. My Duramax got an oil change every 25000 miles or so whether it needed it or not. This one will get AmsOil synthetic and I plan on having an oil analysis done every 15000 miles.
4x4ord is offline
post #8 of 14 Old 04-01-2011, 05:11 PM
twin200's Avatar
Are you serious.Where is your duramax now
Tool box Bull bar
Mike
twin200 is offline
post #9 of 14 Old 04-01-2011, 05:25 PM
4x4ord's Avatar
Quoted: 3 Post(s)
It has all sorts of little issues - radio doesn't, no power door locks, water pump is leaking, radiator should be replaced, transmission needs work, but the engine runs like a top. I checked the oil level about 8 months ago and it needed to be topped up - I honestly can't remember how many miles or years ago it was changed. The truck only has about 120,000 miles on it - I can only remember changing the oil three times.
4x4ord is offline
post #10 of 14 Old 04-01-2011, 07:00 PM
Amsoil is awesome stuff! I wouldn't let it go that long though lol 15k is the max for me but to each their own. I run motorcraft 10w30 diesel oil in mine for warranty purposes. No problems with it at all
2011 ccsb 6.7 Lariat tuxedo black
2006 exlb LLY dmax
Its got some stuff
scorpion is offline
