12v source - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-27-2011, 08:18 PM Thread Starter
12v source
I am getting ready to install a "hard wired" radar detector and I was just wondering where I might find a 12v source (switching power or constant is fine) that I can tap into.
I looked under the dash and found the aux switch wires but I don't want to hook it to a switch like that. can someone help me find a constant power or keyed power wire.
2011 F-350, 5% on sides back and eyebrow-35% on windsheild, B&W hitch, Weather Tech mats, Tailgate Assist, Hornblaster Conductor Special 240, Toyo M/T 35", Incubus Krawler 20x9, 2.5" ready lift stage 3.
cdrracing is offline
post #2 of 6 Old 03-27-2011, 08:47 PM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
Well there are these large boxes under the hood with a big (+) and (-) on the top you want the (+).
I am kidding just tap into the fuse box and use a multimeter to find a good source.
2002 f250 BFT Edition
dereku is offline
post #3 of 6 Old 01-09-2012, 10:09 PM
How bout tapping into your rear view mirror? If you have a Escort passport or a Bell or Valentine One... Inviscord makes a cord that plugs into your rearview mirror power because there is a 12 volt constant and ground. Then you can make a mount that clips off your passenger side sun visor. The Corvette guys do it all the time. Here is some links for you to get an idea.
Radar detector mount (home made) - Improvement over original (pics included) - Corvette Forum
Clean Escort Radar Mount w/pics - Corvette Forum
There you go.. I can get some pics of my set up this weekend
SnakeaterZ06 is offline
post #4 of 6 Old 01-09-2012, 10:32 PM Thread Starter
I ended up mounting it to the left of the steering wheel on the dash (there is a flat spot just to the left of the gauges). I used two strips of ultra sticky Velcro and and set it where I wanted it, then just let it sit for a day or so.
I opened the plastic panel on the drivers side of the dash (that becomes visible when you open the door), I wanted a constant power (not switching with the ignition) so I tracked down and tied into a constant power wire.
As for the ground, I simply found a bolt that was already screwed into metal under the dash, unscrewed it a bit and wrapped the wire around it and screwed it back in.
Then I tucked the wire up and around the pillar where it would stick out enough to reach the radar detector.
I will get pictures as soon as I can.
post #5 of 6 Old 01-10-2012, 01:37 PM
ShirtaDay.com's Avatar
That's not exactly ideal placement for a radar detector. For the best performance, it should be centered, above the windshield wipers, but as close to the dash as possible. It should have unobstructed views forwards and backwards.
ShirtaDay.com is offline
post #6 of 6 Old 01-10-2012, 02:00 PM Thread Starter
I mounted it there because it has perfect front visibility and it is close to power, it also has a flat mounting spot (almost asking for a radar detector).
It doesn't have great rear visibility but I'm not so worried about that.
