Bed Lights - Ford Powerstroke Diesel Forum
post #1 of 18 Old 03-21-2011, 06:27 PM Thread Starter
twin200's Avatar
Bed Lights
I was looking for some white LED light tubes for my bed when I found a kit
that had four 12",two 36" and two 48". The 36 and 48's will connect together
on one switch.The four 12's are seperate for interior application and have a swicth for on/off,strobe,chase and dim (I'm not positive on dim)also sound?
all the lights are blue.so much for my white lights.My bed liner is dolfin grey and with the blue lights everything blends.What do yall think? Just having some fun with this truck
2000 F-350 7.3 4wd cc,dually lariat
afe intake,programmer. rear airbags
2011 F350 6.7 cc,4wd shortbox lariat
Tinted windows Gray bedliner(diy)
Tool box Bull bar
Front aux lights Rear aux lights
Onboard air Train horns
Billet grille LED bed lights
Mike
twin200 is offline
post #2 of 18 Old 03-21-2011, 06:48 PM
67powerstroke's Avatar
Nice work dude.
2011 F250 6.7L
67powerstroke is offline
post #3 of 18 Old 03-21-2011, 07:12 PM
haters gonna hate 24/7.
blueovalman14's Avatar
awesome idea!
where did ya find the kit??
2012 F-150 CC/SB 4x2 Lariat
2005 F-250 CC/LB 4x4 Lariat (Blue/Tan)- Traded In
2005 F-350 CC LB 4x4 Lariat (DSM/Tan) ---> RIP 7/16/2010 (Stolen)
1995 F-350 F-350 CC LB 4x4 XLT
Originally Posted by craftkr View Post
Maybe Choctaw will let you start the LSP Itty Bitty F1Fitty Daycare Chapter????
blueovalman14 is offline
post #4 of 18 Old 03-21-2011, 07:49 PM
BIGBILL105 45's Avatar
Very cool. you should put some smaller bars in the tool box on a pressure switch so when you open it, they turn on.
PM ME FOR VINYL DECALS!
SOLD!!!!!
ARP head studs
4 inch down pipe
5 inch straight pipe
ts 6 pos chip
foil delete w/ polished IC pipes
ugly step delete
2% tint
black lariat rims
35 inch Pro Comp Xterrains
7 inch in dash dvd player
remote starter
16.265
BIGBILL105 45 is offline
post #5 of 18 Old 03-21-2011, 08:00 PM
Koda22's Avatar
Quoted: 5 Post(s)
looks cool, id like to do something like that with my truck...
Koda22 is offline
post #6 of 18 Old 03-22-2011, 08:36 AM
Looks great! I really like the grey bedliner and the bed mat. The lighter color bedliner helps to reflect the light and you can see what's back there. My bed liner is black and the thing is a black hole at night. Good thinking.
BlueF350 is offline
post #7 of 18 Old 03-22-2011, 06:27 PM Thread Starter
twin200's Avatar
Originally Posted by blueovalman14 View Post
awesome idea!
E-bay motors,and I appreciate the comments from everybody
Tool box Bull bar
Mike
twin200 is offline
post #8 of 18 Old 03-27-2011, 12:27 PM
Looks awesome. Working on doing something similar with mine. So how did you mount the lights? Screw, double-sided tape? Did you wire to an upfitter switch or to an alternate 12V source with a separate switch?
2011 F-250 SD Lariat
6.7 Powerstroke Diesel
Crew Cab Short Bed
TurbineDoc is offline
post #9 of 18 Old 03-27-2011, 12:34 PM
grmreaper's Avatar
Looks great, thats for sure. Let us know how the hold up. I have been intersted in something like this, but i drive on rough a** roads alot so they would have to be tough to hold up.
2011 F350,CC,LB,Lariat,4x4,FX4,6.7L
2.5" Leveling kit - H&S Tuned and DPF bye bye
6k 55W Bi-xenon Morimoto Mini (H1) Projectors and HID fog lights
18x9 Fuel Hostage Black and Brushed wrapped with 325/65/R18's
JL audio 900/5 AMP, JL CleanSweep, JL 13TW5 sub
Waiting to be installed: EGR delete
On order: S&B intake - now 9 weeks and counting
grmreaper is offline
post #10 of 18 Old 03-27-2011, 01:57 PM Thread Starter
twin200's Avatar
The lights I got came with some plastic brackets.The bracket has one screw for mounting and the tube snaps into the bracket,then I also put a zip-tie around lite and bracket.Just under the top rail inside,there's room for a screw without coming in contact with truck body.They come with a on/off switch that put under top rail with double-sided tape with easy access to run them or not.I tapped in the plate light for this.I believe these lights pull less than 2 amps(need to check on that 2 amp,not for sure)
Tool box Bull bar
Mike
twin200 is offline
