NEW TSB (11-3-23) FOR CEL AND SHIFT ISSUES - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-18-2011, 09:53 AM Thread Starter
Hope this is the one that finally fixed the shift issues....
FORD: 2011 F-250, F-350, F-450, F-550
This article supersedes TSB 10-23-9 to add additional calibration content.
ISSUE:
Some 2011 F-Super Duty vehicles equipped with a 6.7L engine and built on or before 3/14/2011 may exhibit malfunction indicator light (MIL) on with diagnostic trouble codes (DTC's) P0401, P0402, P009A if driven at highway speeds with a snow plow attached, P164A if idled for extended periods in colder ambient temperatures, 2-3 transmission shift flares, harsh/inconsistent transmission shifting during transmission fluid warm up and tip-in events when at low speeds or coming to a stop. Refer to the Calibration Content for additional details.
ACTION:
Follow the Service Procedure to correct the concern
SERVICE PROCEDURE
Reprogram the powertrain control module (PCM) and the transmission control module (TCM) to the latest calibration using IDS release 71.05 and higher or 72.01 and higher. This new calibration is not included in the VCM 2011.3 DVD.
The Calibration Update Contains Improvement Actions And Enhancements:
DTC P0401 (exhaust gas recirculation (EGR) flow insufficient detected)
DTC P0402 (exhaust gas recirculation (EGR) flow excessive detected)
DTC P009A (intake air temperature/ambient air temperature correlation) if driven at highway speeds with a snow plow attached
False DTC P164A (O2 sensor positive current trim circuit performance (bank 1, sensor 1)) if idled for extended periods in colder ambient temperature
Harsh/inconsistent transmission shifting during transmission fluid warm up
Improved shift feel for tip-in events when at low speed or coming to a stop
Previously Released Calibration Content
Previously released calibration content included in IDS software release 69.07 and higher contained improvement actions and enhancements to address the following:
Calibration Content Vehicles Built On Or Before 11/5/2010
Delayed manual upshifts from 1st to 2nd gear when in Select Shift mode while going down a grade
Harsh/delayed 1-2 upshift and downshift
Harsh 2-3 upshift on first drive away of day after vehicle soak
DEF warning messages won't reset after refilling DEF tank with Key On Engine Running
Modified vehicles for rail applications, that will not re-engage PTO operation or speedometer inoperative after riding on the tracks with the front wheels off the ground
VSOUT signal inoperable from customer access circuits under dash
DTC P2463 or P246C (DPF restriction) and DTC P2459 (DPF regeneration frequency) - adds increased ability to perform manual regeneration at higher load values when performing system diagnostics
Calibration Content - Vehicles Built On Or Before 08/23/2010
False DTC P132B (turbocharger/supercharger boost control A performance)
False DTC P0299 (turbocharger/supercharger A under-boost condition)
False DTC P050E (cold start engine exhaust temperature too low)
False DTC P06EA (NOX sensor processor performance (bank 1, sensor 1)
DTC P249C (SCR time to closed loop) - improved diagnostics and reporting
DTC P249F (excessive time to enter closed loop DPF regeneration control) - improved diagnostics and reporting
False DTC P0884 (PCM/TCM power input signal intermittent)
DTC(s) and freeze frame data being erased in the PCM when running KOEO, KOER, Datalogger, Active Commands or any other guided diagnostics with IDS
False P0731 (gear 1 incorrect ratio)
False P0732 (gear 2 incorrect ratio)
False P0733 (gear 3 incorrect ratio)
False P0734 (gear 4 incorrect ratio)
False P0735 (gear 5 incorrect ratio)
False P0729 (gear 6 incorrect ratio)
Low speed/load engine surge
Abrupt engine shutdown feel
HP fuel pump knocking noise at idle
Delayed DEF level indication after refill event
Harsh/bumpy transmission upshifts/downshifts
Delayed/harsh transmission engagement feel between R-D and D-R shifts
Transmission gear hunting during speed control operation when climbing grades or climbing hills, particularly while towing
Erratic transmission operation after descending grades while in 1st gear
Flashes/delays of current gear indication when using SelectShift mode
Added Brake Over Accelerator (BOA) feature - reduces engine power during off-idle driving when both the accelerator and brake pedals are applied simultaneously
Added SelectShift memory feature, so SelectShift gear display comes back on whenever going back into drive if the vehicle was turned off while SelectShift mode was still activated
Added engine protection feature from overspeed while descending long grades while towing and in manual gear ranges (forces transmission upshifts at 4000 RPM)
Increased torque - during hill assist operation - (see Owner Guide for additional system operation)
PTO operational enhancements - (applicable to vehicles equipped with optional PTO)
- Automatic secondary electronic idle controller (SEIC) turns on at engine start if the switch in on position
- Engine coolant temperature to operate PTO lowered to -7 C (+20 F)
- Improved RPM control with SEIC controllers
frt2599 is offline
post #2 of 5 Old 03-18-2011, 04:15 PM
I am not sure what all of that means, but my check engine light has been permanently on for 3 weeks. The dealership said they were waiting for a reprogram fix. They say the light generates from cold temp related issues. They can turn it off, but it comes back on. Hopefully this fixes it.
mrock is offline
post #3 of 5 Old 03-18-2011, 08:38 PM
vrsc's Avatar
I have an H&S mini max in my 2011 6.7 and I started experiencing trans shifting problems! I need this updated PCM flash so what does this mean for me and my tuner? Can I get it or not?
H&S please assist
2011 F250 Golden Bronze/Arizona Beige Fully Loaded King Ranch FX4 with Navigation, 6.7 PSD, 4x4 E-locker, Color Matched Line-x Bed and toolbox, Icon Vehicle Dynamics/One Up Offroad Suspension Lift, BMF Novakaine 8 Chrome 20x10, Toyo M/T 37x13.50x20, Color matched Brake Calipers, Amp Research Steps, H+S Mini Beta, CAT/DPF delete, AFE intake and 1000 watts of JL Audio and Focal
vrsc is offline
post #4 of 5 Old 03-18-2011, 09:11 PM
matty21's Avatar
H&S please assist
same here.
what to do
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #5 of 5 Old 04-07-2011, 06:39 AM
doczenith1's Avatar
Quoted: 8 Post(s)
I'm pretty certain that TSB has been recalled. It was out for about a week before they recalled it. Rumor is it will be back out near the end of April.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
