Firestone Airbags - Ford Powerstroke Diesel Forum
post #1 of 35 Old 03-11-2011, 08:57 PM Thread Starter
superdave267's Avatar
Firestone Airbags
Anyone running the Firestone Airbag's on the rear of their 2011 F250 SD? If so how are they working out loaded and unloaded.
superdave267 is offline
post #2 of 35 Old 03-11-2011, 09:31 PM
Clintd's Avatar
I'm running them on my f350 and can't tell any difference unloaded. I have tried several different pressures looking for a sweet spot for better ride. If there is one I have not found it. As far as loaded works like it should. Levels the truck. Well worth the money IMO.
2011 F350 Black King Ranch 4x4 DRW, 255/80R17 BFG KM2, NFAB steps, Weather Guard tool box, 2.5 icon leveling kit, 4in rear block, Icon 2.0 shocks, Black Ultra Goliath wheels, Road Armor Bumpers, 8-510 Piaa Lights (front), 2-1400 Piaa Lights (rear), Firestone Ride Rite Bags, Compressor,Tank, Single Gauge Air Control
More Pics in my Albums
Clintd is offline
post #3 of 35 Old 03-11-2011, 09:50 PM Thread Starter
Will it lift the rear and if so does it make the ride worse.
post #4 of 35 Old 03-12-2011, 04:30 AM
I have the firestone air bags and the airlift 72000 wireless compressor on my 2011 F250. When unloaded you are suppose to run 5 PSI in the bags. When loaded you can go up to 100 PSI. I can't tell any difference when unloaded. I have heard nothing but good things of how they help when towing. I have a 29ft. bumper pull toy hauler and was getting some sag even with the weight distribution hitch. Thus why I installed the bags. Haven/t had the chance to tow with them yet but looking forward to it. The install is not too bad. A little tight on the driver side with the tanks on that side. I would recommend getting the wireless remote air as it really COOL....
frt2599 is offline
post #5 of 35 Old 03-12-2011, 05:14 AM
wnsniper's Avatar
I have the airbags on my 04 250. I tow a 37ft. 5th wheel. Really helps with leveling a heavy load. I keep about 5lbs of pressure in them when not towing and the ride is no different then before I put them on. I think they are a must when towing heavy loads.
wnsniper is offline
post #6 of 35 Old 03-13-2011, 03:02 PM
Any Forum vendors sells them? I'm towing an 32 ' car hauler and using a equilizer hitch and still getting sag. How is the ride when towing a heavy load?
jeostang is offline
post #7 of 35 Old 03-13-2011, 03:35 PM
Do you happen to have any pics of how you mounted the compressor?
jeostang is offline
post #8 of 35 Old 03-13-2011, 03:45 PM
Nthorseman's Avatar
EpicCowlick has posted a video. Search for it. It's quite helpful and the install only takes 10 video minutes...
2011, F250 Lariat, Green, 4x4, 6.7L, Longbox, SRW, 3.55 gears, Upfitter switches, Moon/Sunroof, Leather seats, High idle, Rapid heater
Nthorseman is offline
post #9 of 35 Old 03-13-2011, 05:10 PM
Thanks for the info, he has a awesome vid.
Going to order this before the next trip.
here is the vid
jeostang is offline
post #10 of 35 Old 03-13-2011, 05:15 PM Thread Starter
I plan to use this to install mine. Already ordered them. Looks easy.
2011 Ford F-250 Super Duty 6.7L "Scorpion" Powerstroke, Lariat, CC, LWB, 4X4, FX4, RECON LED cab lights, more to come...
First time Ford owner hope this truck holds up.
[/CENTER]
2008 Harley-Davidson FXSTB Night Train [/CENTER]
Dodge Ram 2500 6.7L Cummins Quad Cab 4X4, Firestone Ride Rite
