2.5" Receiver Tow & Stow w/ 3 Balls? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-17-2011, 06:19 AM Thread Starter
ShirtaDay.com's Avatar
So.... can someone point me in the direction of a tow and stow hitch that works with the 2.5" hitch on these new trucks?
Over the years I've accumulated lots of hitch & hitch accessories, but they're all the standard 2". This new truck is 2.5" and none of that really works anymore.
I also have a small BBQ trailer with a 1 7/8" ball, the boat with a 2" ball and a travel trailer with a 2 5/16" ball....
I've been talking about getting a 3-ball stow & go for some time, but now, since I need to buy a new hitch, would be the perfect time, but I can't seem to find a 2.5" model. Am I just retarded?
'17 F-250 KR
ShirtaDay.com is offline
post #2 of 15 Old 02-17-2011, 06:42 AM
mor4wd's Avatar
Just get the sleeve to make the 2.5" a 2". Unless your towing 16k off the bumper, you don't need the 2.5".
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 15 Old 02-17-2011, 06:46 AM Thread Starter
Travel trailer w/ BBQ trailer behind it will be just over 10k normally - up to 11k maybe? Wouldn't mind just having the peace of mind with the 2.5" hitch (if I can find what I need).
'17 F-250 KR
post #4 of 15 Old 02-17-2011, 06:55 AM
mor4wd's Avatar
Best I could find Fits 2-1/2 Inch Hitch Ball Mounts | etrailer.com. It's only a double ball. I searched for a long time for a triple ball with the 2.5 shaft but couldn't find it.
mor4wd is offline
post #5 of 15 Old 02-17-2011, 07:09 AM Thread Starter
Is there an adjustable height that allows you to attach a regular ball? Then I could get one of those 3-in-1 balls?
'17 F-250 KR
post #6 of 15 Old 02-17-2011, 10:53 AM
If I were you I would just replace the 1 7/8" tongue and put a two inch on and down to two ball sizes. I bought the DP Tech for my 2.5" and fits in great.
bajasst is offline
post #7 of 15 Old 02-17-2011, 11:20 AM
teameyecatcher's Avatar
3-in-1 balls are only rated to 8k, even for the 2 15/16. I had a hell of a ball mount set up on my last truck, and this 2.5" hitch is screwing me up. I got a sleeve to fit in there but that thing is NOT coming out. I had to hammer it in.
Instead of buying new tow-n-stows or drawbars, etc, just get a new hitch. The factory hitch sucks with weight ratings, so youd be better off paying $180 for a new 2" class V.
For instance - factory 2.5" is rated for 8,000 weight carrying, 12k weight distributing with a 2.5" drawbar, and only up to 6,000 using a sleeve. You can buy a curt 2" hitch with a 15,000lb weight carrying rating and 16,000 weight distributing. Remember, you have to have that full-all-out get up to use the weight distributing...not just clipping on the ball. I plan to upgrade ASAP, but I havent had a need to tow over 6k yet. I did it on my last truck when towing a 14k boat, because you dont want to get in a wreck and have insurance look at the overweight on the hitch rating.
etrailer.com has great customer service, but I've gotten most of my hitches from hitchesonline.com
2011 6.7l F-250 Lariat FX4. Tuxedo Black with tan bottom/Black interior
-2" Readylift
-Avery clear bra/painted grille surround, KR bumpers
-Recon LED cab light kit, dually under tailgate light.
-Black bedlined toolbox. Black bedliner, dual cable locks, and factory bed extender
-Yellow tops, lockpick.
-Legal window tint
teameyecatcher is offline
post #8 of 15 Old 02-17-2011, 11:26 AM Thread Starter
I believe mine had some 14.5k option on the sticker for the hitch?
'17 F-250 KR
post #9 of 15 Old 02-17-2011, 11:33 AM
Better check. Look on the hitch itself and the specs should be listed. Even if its 14.5k, I assume its only for weight distribution. Probably still 8k weight carrying.
-2" Readylift
-Legal window tint
post #10 of 15 Old 02-17-2011, 11:37 AM Thread Starter
Well, we're getting a weight distributing setup for the travel trailer, so no worries there, whether it's 12k or 14.5k. And the boat is under 6k. So the current hitch should be fine....
Looks like I just need to figure out my ball situation - maybe changing the 1 7/8" trailer to a 2" will be the easiest option. For some reason I don't want to use a 2.5" to 2" adapter.
'17 F-250 KR
