"shift delayed, pull forward." - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-02-2011, 08:43 AM Thread Starter
Got caught in a pile of snow this morning. Attempted to swith to 4x4 high, but got "shift delayed, pull forward" message. I giggled. I talked to my truck and explained how that if I could "pull forward," I wouldn't need to shift. Fortunately, the truck didn't answer back.
Figuring that the truck doesn't know whether I'm moving or not, I left it in drive and gave it a little bump in rpms. Still no luck. It finally went into 4x4 when I put it in reverse.
I'm sure there's a technical reason for this, but I'm at a loss. I know the owners manual says that it's best to moving foward at a slow rate of speed when transferring to 4x4 high, but bumping the accelerator for 2 or 3 seconds didn't do the trick.
2011 F250 XLT 6.7 PSD 4X4 Crew 3.31 rear-end in Sterling Grey
1tough_crew is offline
post #2 of 5 Old 02-02-2011, 08:46 AM
fbomb's Avatar
The transfer case gears need to line up......Normal.....
2011 F250 FX4 Lariat TUXEDO BLACK....H&S BLACK MAX, S&B INTAKE,4 INCH EXHAUST,READY LIFT KIT 2.5F 2.0R
BMF 20X9 RIMS,NITTO 35X12 TIRES...
fbomb is offline
post #3 of 5 Old 02-02-2011, 09:48 PM
richc22a's Avatar
I have the Sync communication package. My truck talks to me, if it talks back I threaten to fill the DEF with my own urea. That usually does the trick.
"Back when" going to 4x4 was manual, you would pull the lever and sometimes you had to move/rock forward, backwards to get the gears to mesh...get 4x4 and...climb stuff.
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #4 of 5 Old 02-03-2011, 05:03 PM
I still prefer to pull the lever back.
jimchris is offline
post #5 of 5 Old 02-03-2011, 05:52 PM
2003kingranch's Avatar
[QUOTE=richc22a;2329386]I have the Sync communication package. My truck talks to me, if it talks back I threaten to fill the DEF with my own urea. That usually does the trick.
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
