2011 engine braking system - Ford Powerstroke Diesel Forum
post #1 of 38 Old 01-31-2011, 04:37 AM Thread Starter
Needing some info. Looking at buying the new 20011 but really want to know if the engine braking system works. Usually hauling 20,000# down a 7% grade in Colorado. I just want to know if anyone has used it to that extreme and if it really works. Any info is great.
THanks
2003 6.0 F250 Long Bed 4x4 red. Chrome steps, and tool box. Front replacement bull nose bumber. Green Air filter, 4"exhaust with cat/muffler delete. Zoodad mod. High Idle Mod. Superchip Flashpaq 1805, Sirius Radio.
cappy is offline
post #2 of 38 Old 01-31-2011, 05:25 AM
mor4wd's Avatar
In my experience, if you use it the way it is supposed to be used, in conjunction with the cruise control, then it works great. I haven't had 20,000 behind me yet, but 14,000 going down 9% it holds the speed within 3 mph of what I have set, and by tapping the decel button you can really feel it working.
There's a thread on here somewhere with a lot of posts about this.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 38 Old 02-02-2011, 08:08 PM
4506dave's Avatar
Pulling bobcat (12000lbs) I don't notice a damn thing. Feels the same as my 09 did. Maybe it's just me
Currently own
2012 Ram 2500 Longhon, 6.7 Cummins
2010 Jeep Grand Cherokee SRT8, Predator tune Mopar CAI
2008 Saturn Sky RED LINE, GM stage 2 kit with GMPP CAI
2007 Dodge Ram 1500 5.7 Hemi, Superchips tune AFE CAI
I'm Lovin it
Gone
2011 Red F350 Lariat SRW CC SB 3.55 E-locker FX4-Roll n Lock Bed cover, Titan xl fuel tank
2009 Ford F350 Harley Davidson, 3.5" SST Ready Lift, 35x12.5x20 Wrangler Duratracs, Firestone Airbag Kit, S & B CAI, 5" Flo Pro Exhaust , Spartan 310.
4506dave is offline
post #4 of 38 Old 02-03-2011, 05:43 AM
TW720HVY's Avatar
Quoted: 2 Post(s)
I agree with this statement, I do not notice any form of engine braking what so ever. I pull a heavy cargo trailer and boat with ours and I spend a lot of time on roads that are hilly and curvy where cruise control is not a good idea but engine braking is. This system is very weak in my opinion and if you're wanting an engine brake you can have absolute control over then this is not the truck. Test drive all three and pick the right one that fits your needs.
Now with this being said... I love the 6.7 and hands down the best HD trucks I have ever owned even with the let down with the exhaust/engine brake.
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #5 of 38 Old 02-03-2011, 03:41 PM
I have not towed 20K but have a couple of thousand miles at 18K GCVW. The exaust break will hold that load at 45 MPH on a 9% grade with no problem. It is not a "Jake" break that you turn off or on. It is not related to cruse control but is more of a reverse cruse control if you will. For example you "turn it on" by engaging tow/haul like you would with the ON button for the cruse control. You engage by tapping the brake, like you would engage cruse with the SET button. The truck will then use the TCM and variable turbo based exaust restriction to try to maintain that speed. A second application of the break will set a slower speed like the COAST button does for cruse. Application of the throttle will increase the target speed like the ACCEL button does for the cruse.
tspendlove is offline
post #6 of 38 Old 02-03-2011, 04:11 PM
TW720HVY's Avatar
Quoted: 2 Post(s)
I agree it does do what you described but I see that as simply down shifting, just like my old Alison did. Down shift, then higher engine RPM with boost (just a couple of pounds) being the byproduct from the higher RPM... I must be really thick in the head but again I do not see this as an exhaust brake, never mind an effect "exhaust brake".
My old Duramax did the same thing and there was no exhaust brake advertised. The TCM and 6 speed works well and love it .. but again I am not feeling any exhaust braking what so ever.
Surely 4506dave and I cannot be the only ones not sold on this "exhaust braking" system.
I give up and I am certainly not going to brag about this option.
Previously Owned
TW720HVY is offline
post #7 of 38 Old 02-04-2011, 03:26 AM
matty21's Avatar
id rather a true exhaust break, that i can control manually
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #8 of 38 Old 02-04-2011, 05:49 AM
mor4wd's Avatar
You have to remember that diesels, by nature of their design, don't have diddly squat for compression braking, very different from gasoline motors that do. Any braking you're feeling is with assistance of the exhaust brake.
mor4wd is offline
post #9 of 38 Old 02-04-2011, 12:21 PM
TW720HVY's Avatar
Quoted: 2 Post(s)
I see and understand your point. But my '04 GMC Dmax Allison did the same thing when it downshifted and that truck did not have an exhaust brake or so they did not advertise.
As I down shifted in that truck I felt the same thing as I did as I down shifted in a Pete with the "jake" off as I feel when I down shift in my F-350. I understand an exhaust brake to work in a manner that does not require the use of the vehicles brakes.
Exhaust brake - Wikipedia, the free encyclopedia
"More performance is usually easily had by down shifting the vehicle (increasing the leverage, or gear ratio of the engine over the wheels)."
Previously Owned
TW720HVY is offline
post #10 of 38 Old 02-04-2011, 01:04 PM
mor4wd's Avatar
I actually called Ford Customer Service to try and get more details on the exhaust brake. I talked to them for 45 mins and they had no more information than what I could find in the manual. Basically nothing. They said that they would have a purchasing agent who knows a lot about these trucks call me, but he never did.
mor4wd is offline
