"Cleaning Exhaust Filter" Question - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 19 Old 01-30-2011, 04:39 PM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
I have gotten this message a couple of times and just wondering what is going on.
What causes this message to appear?
What is actually happening (system wise) when it is cleaning the filter?
What happens if it starts cleaning right when you shut down?
Thanks.
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
The Following 2 Users Say Thank You to TW720HVY For This Useful Post:
BIG RED BUBBA (08-25-2016)
post #2 of 19 Old 01-30-2011, 05:57 PM
Mason73's Avatar
That's a good question, I was wondering the same thing. What if I am pulling in my driveway and that stupid "cleaning exhaust filter" message come on, am I suppose to just keep driving around the neighborhood till all that raw fuel is burned out of the exhaust system?
2011 F-250 XLT CC LB 4X4
Mason73 is offline
post #3 of 19 Old 01-30-2011, 07:47 PM
Spunky250's Avatar
I have shut down within a minute or so of the light coming on well before the cycle should be complete and just shut down like normal. On the drive after the two times I have done this, the message will reappear and the cycle will begin again when the motor gets up to a decent operating temp (160-190). Not sure if it picks up where it left off, or starts and entirely new cycle... I wish there were an indicator to tell you those sorts of things.
Spunky250 is offline
post #4 of 19 Old 01-31-2011, 05:32 AM
mor4wd's Avatar
It will restart from the beginning upon shut down and restart, not that it has a beginning, but there is an end. It's based off back pressure in the DPF, once the pressure is above a certain threshold it begins the cleaning and ends when pressure is reduced.
The way it cleans is it injects raw fuel into the exhaust system, which becomes superheated in the DPF, essentially burning the soot out of the system, it's like a Catalytic Converter on steroids.
If it starts right before shut down, nothing happens. Don't let the DPF run your life. It won't cause damage.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #5 of 19 Old 01-31-2011, 11:30 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
Thanks everyone.
So when the message appears it is injecting raw fuel to burn off the soot through the use of an ignition (glow plug) source? Is the DEF part of a different system?
Previously Owned
TW720HVY is offline
post #6 of 19 Old 01-31-2011, 11:35 AM
it heats up insanely.. that is why the special tips on the exhaust to disperse it, i've seen melted mudflaps galore.. also the DEF is after apparently to cut the NOx even more. im not sure. its all a bunch of crap to me and messes up these trucks in the long run i say DELETE..
Dietoremain is offline
post #7 of 19 Old 01-31-2011, 12:17 PM
mor4wd's Avatar
Originally Posted by TW720HVY View Post
Thanks everyone.
No additional ignition source. The DPF is hot enough that it self ignites. The DEF is separate. It is injected directly into the exhaust system after the DPF to further neutralize NoX emissions.
It is all just a big mess to satisfy the people who still believe in global warming along with Al Gore and his buds. Emissions regulation are only going to get more strict in the next couple of years.
mor4wd is offline
post #8 of 19 Old 01-31-2011, 05:53 PM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
Thanks guys... I am still trying to understand this truck's systems.
Previously Owned
TW720HVY is offline
post #9 of 19 Old 02-02-2011, 07:33 AM
You have a lot of company. I carry the owner's manual around with me.
C.B. likes this.
2011 F250 XLT 6.7 PSD 4X4 Crew 3.31 rear-end in Sterling Grey
1tough_crew is offline
post #10 of 19 Old 02-02-2011, 10:06 AM
I'll keep it simple as I can (don't know much more)
You are discussing TWO seperate systems on our trucks.
The OP's original question was about the Diesel Particulate Filter or DPF.
Then, the Diesel Exhaust Fluid - DEF - came into the thread.
Both are smog items required by the government. MANY of us cannot "Delete" either of these and get license plates in our states. Also, deleting the DPF would be very costly in the great reduction your truck would have for trade-in/sale value. The DPF is very, very expensive to replace so a truck without one would be worth far less in states that require them, and that list of states continues to grow. (thanks EPA)
OK, the DPF collects the solid particles that are part of diesel exhaust. You have seen them as black smoke. A stock 6.7 Powerstroke does not blow any black smoke if it is working correctly. The DPF looks like a large muffler with sensor wires coming out the sides (look under your truck). I believe they are made of a honeycomb ceramic stuff.
As the diesel works the DPF collects carbon particles until it "fills up". Sensors tell the computer the DPF needs cleaned and thats when you get the info in your read-out on the dash "cleaning exhaust filter". Extra diesel fuel is introduced into the exhaust flow and burns. This causes the DPF to become very hot (like a self cleaning oven) and burns the collected particles into harmless ash which is blown overboard.
This cleaning cycle lasts up to 20 minutes which include heating up, burning clean and then cooling back down to normal temp. If possible, try to run your truck long enough for the cycle to finish - - but you do not have to do this.
If you shut down before the cleaning cycle finishes, it will begin all over again the next time your truck is at operating temp. If you shut down during a cleaning cycle you will prolly smell the "heat" of the exhaust system as it has not got to the cool down portion of the cycle. Do not touch any part of the exhaust as it will be extremely hot!!
Now, on to the DEF, , , , ,
DEF is injected into the exhaust as the truck runs. The amount injected varies with load, temp and other factors but it is injected most of the time the engine is running. DEF reduces the vapor emissions in the exhaust.
There you have it - - DEF is for vapor control and the DPF collects solids. TWO seperate systems but both are in the exaust plumbing.
I have to say these systems both work well. I can run my truck in the garage and never smell diesel oder. If you watch your mirror while you are at full throttle, you will not see any smoke (unless you are lucky enough to be able to delete these systems).
As far as the cost of the DPF - I'm not sure but I have heard 10 grand!! I do know they are not cheap and you do not want to throw a good one away. I have also heard Ford expects the DPF on our trucks to last at least 100k miles so it is not something that will ding our pockets often. Just don't toss it away in the garbage if you take it off!!!
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
