DEF fluid warning light - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-26-2011, 02:43 PM Thread Starter
Got in truck today DEf warning light came on saying 700 miles to empty, only been 2000 miles since last oil change and fill up, went to dealer and told them to fill it up and see what happens, only took 2 gal's. they called ford and they said to reflash it, already had the 400-800 flash theres another new flash out not sure what all it does but it shifts better now than it ever has.
jbm49u is offline
post #2 of 9 Old 01-26-2011, 03:21 PM
Ren
Ren's Avatar
hmmmmm... new flash.
Wonder if there is a tsb for this.
2011 6.7L F350 DRW CrewCab
Our adventures,
Ren is offline
post #3 of 9 Old 01-26-2011, 03:43 PM
Probably a dumb question, but what is a tsb?
2015 Lariat F350 FX4 CC/LB SRW 3.55's Ignot Silver Zone 4" Lift Nitto Trail Grapplers 295x65x20 UWS ToolBox
Robertc82 is offline
post #4 of 9 Old 01-26-2011, 04:22 PM
brmccolley's Avatar
TSP = Technical Service Bulletin
I'd find it hard to find that there would be another ECU software version so soon. My guess is that the re-flash would just reset everything in the ECU.
brmccolley is offline
post #5 of 9 Old 01-26-2011, 04:47 PM Thread Starter
well they did the 400-800 when it came out and i asked if it was the same they said no, so thats all i know other than i saw part of it and it did say to correct issues with shifting along with some others I didnt read
jbm49u is offline
post #6 of 9 Old 01-26-2011, 04:51 PM
doczenith1's Avatar
Quoted: 8 Post(s)
There was a TSB for a transmission issue that came out after the 400/800 flash. It was sometime in late November or early December I believe. The main thing addressed with the flash was the transmission shifting issues.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #7 of 9 Old 01-27-2011, 05:38 AM
brmccolley's Avatar
No issues
I bought my KR in April and had the 400/800 flash in September. I was informed that the flash included the transmission and noticed smother shifting at that time. I haven't had any shifting issues since the flash in September and I haven't been notified of any need to return to the dealership to be flashed again.
I noted at http://www.mycarstats.com/reports/fo...omplaints.aspx that the date, service bulletin number and NHTSA item number is the same for both the 400/800 flash and the transmission issue. I think I probably got both in September.
post #8 of 9 Old 01-27-2011, 07:56 AM
doczenith1's Avatar
Quoted: 8 Post(s)
I'm fairly certain that there was a flash that came out after the 400/800 flash that targeted transmission issues. I'll do some digging and get the details.
Al Bedford, P.E.
post #9 of 9 Old 01-27-2011, 10:04 AM
doczenith1's Avatar
Quoted: 8 Post(s)
Found it.
TSB 10-23-9 6.7l - calibration update - various issues - built on or before 11/5/2010
Al Bedford, P.E.
