Keyless Entry - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-19-2011, 11:50 AM Thread Starter
Keyless Entry
Just bought an F250 KR CC 4x4 last week and I was told by the salesman that the keyless entry code will come when I get my plates in. Has anybody else got this answer?
gcollier is offline
post #2 of 20 Old 01-19-2011, 12:10 PM
mor4wd's Avatar
It should be in the manual. I think he's covering because he lost it.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 20 Old 01-19-2011, 12:14 PM Thread Starter
Ok thanks, I will look in the manual when I get home from work.
gcollier is offline
post #4 of 20 Old 01-19-2011, 02:15 PM
mor4wd's Avatar
It's a little wallet size card with 5 numbers printed on it with the fancy Ford writing on it.
mor4wd is offline
post #5 of 20 Old 01-19-2011, 02:29 PM
Like he said, it should be in the manual. If you can't find it though, they should be able to look it up or something and tell you what it is. Then you can change the code to whatever you want it to be so it is easily remembered.
2015 Lariat F350 FX4 CC/LB SRW 3.55's Ignot Silver Zone 4" Lift Nitto Trail Grapplers 295x65x20 UWS ToolBox
Robertc82 is offline
post #6 of 20 Old 01-19-2011, 05:50 PM
how do you change it?
bigsakius is offline
post #7 of 20 Old 01-19-2011, 06:08 PM
I'm want to say it on page 113 or 114 in the manual. Trying to remember if thats right or not. But its in there pretty easy to change
pipeliner08 is offline
post #8 of 20 Old 01-19-2011, 07:39 PM
If i'm not mistaken I believe you need the original code or the one you currently use to get in the truck to change to a different code.
strkngator is offline
post #9 of 20 Old 01-19-2011, 07:53 PM
Spunky250's Avatar
If you have Navigation, you should be able to change it on there. Just a thought to get you moving quicker.
Spunky250 is offline
post #10 of 20 Old 01-20-2011, 05:25 AM
mor4wd's Avatar
You will need the original code to change it, you can't use a custom code to change it. I don't remember seeing anything in the nav manual for changing it, but who knows. If you can't find it then the dealer can get it, you just have to provide proof of ownership.
mor4wd is offline
