How do you reset the oil sensor after you change it?? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-16-2011, 12:59 PM Thread Starter
ErnieT's Avatar
I do my own oil changes but can't figure out how to reset the computer. Anyone??
ErnieT is offline
post #2 of 7 Old 01-16-2011, 04:08 PM
In my chevy suburban, I had to cycle the key on-off-of and mash the gas peddle 3 times in 5 second (I think). It was described in the owners maual. I'd look there for some info. Or call the ford dealer?
2004 F250 CC SB 4x4 Lariat
WIX intake with zoodad mod
(05 & up) Innovative Diesel intake elbow with butterfly valve manifold removed
4" SS T-Back no kitty exhaust
SCT X3 w/ I.D. Custom Tunes
Gauges: EGT, Boost, Tranny Temp
Pace Edwards bed cover / B&W Gooseneck Hitch / Linex
DieselSite coolant filtration system
DC Power Engineering 250A Alternator
Submariners do it deeper!!!
ShawnCT450R is offline
post #3 of 7 Old 01-16-2011, 04:29 PM
assistant director
thbd77's Avatar
look in the owners manual. on newer chevy trucks it is key on a hit the gas pedal 3 times to the floor in 5 seconds
Name-Troy Lincoln
96 F-250 4X4 stroked xcab shortbed 5 speed
01 EXCURSION LIMITED 4X4 V-10 brute force intake dual exhaust
02 EXCURSION LIMITED 4X4 stroked ts 6 position 4" dp and duals hers now
06 F-250 4x4 6.0 auto lariat crew cab short bed Dads ride
thbd77 is offline
post #4 of 7 Old 01-16-2011, 04:54 PM Thread Starter
ErnieT's Avatar
I looked. Not there.
ErnieT is offline
post #5 of 7 Old 01-16-2011, 04:58 PM
Might be on the in-dash computer, like oil life - reset or something of the sort.
Jimmy7060 is offline
post #6 of 7 Old 01-16-2011, 05:00 PM Thread Starter
ErnieT's Avatar
Tried that too. Only shows an "ok" or change oil soon.
ErnieT is offline
post #7 of 7 Old 01-16-2011, 05:05 PM
Stole this from somewhere else. Figured it was general Ford stuff, worth a try.
There are three types of dashes
Oil Life Reset - Message Center Cluster
Press and release the SETUP button until the message center displays OIL LIFE XXX% HOLD RESET = NEW OIL.
Press and hold the RESET button for 2 seconds and release when the message center displays OIL LIFE SET TO XXX%.
Press and release the SETUP button to exit the procedure.
Oil Life Reset - Base Instrument Cluster (IC)
NOTE: All message center functions are carried out using the single stem SELECT/RESET button in the Instrument Cluster (IC).
Press and release the SELECT/RESET button to scroll through the information displays until the message center displays HOLD RESET FOR SETUP MENU.
Press and hold the SELECT/RESET button for approximately 2 seconds until the message center displays OIL LIFE XXX% HOLD RESET = NEW.
Press and hold the SELECT/RESET button for approximately 2 seconds until the message center displays OIL LIFE SET TO XXX%.
Release the SELECT/RESET button and allow the setup timer to expire to exit the procedure.
Oil Life Start Value - Message Center Cluster
Press and release the RESET button to decrease the oil life start value (from 100% to 10%) for each 10% reduction until the desired oil life start value is displayed.
Oil Life Start Value - Base Instrument Cluster (IC)
NOTE: The oil life start value reduces by 10% for each second that the SELECT/RESET button is held once the oil life start value begins decreasing.
Continue to hold the SELECT/RESET button until the oil life begins to decrease in value (from 100% down to 10%), continuing to hold until the desired start value is displayed.
Latetowork is offline
