Towing with a lift??? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-09-2011, 09:21 PM Thread Starter
4506dave's Avatar
Do any of you fine fellows with lift kits tow a 5th wheel? I did with my 09 and thinking of lifting this one but would like a 6" and 37's, which might be a little high. My last truck was ok with the lift listed in my sig. What's your thoughts?
Currently own
2012 Ram 2500 Longhon, 6.7 Cummins
2010 Jeep Grand Cherokee SRT8, Predator tune Mopar CAI
2008 Saturn Sky RED LINE, GM stage 2 kit with GMPP CAI
2007 Dodge Ram 1500 5.7 Hemi, Superchips tune AFE CAI
I'm Lovin it
Gone
2011 Red F350 Lariat SRW CC SB 3.55 E-locker FX4-Roll n Lock Bed cover, Titan xl fuel tank
2009 Ford F350 Harley Davidson, 3.5" SST Ready Lift, 35x12.5x20 Wrangler Duratracs, Firestone Airbag Kit, S & B CAI, 5" Flo Pro Exhaust , Spartan 310.
4506dave is offline
post #2 of 10 Old 01-10-2011, 06:03 AM
Ren
Ren's Avatar
My thoughts are dont do it. As all trucks I have seen lifted usually dont do all that well. Everytime I follow a lifted truck towing...mostly trailers as they are too high for the 5ver to sit correctly on the truck. They sway back and forth lots more than stock trucks. I guess good sway bars would help. Also towing a 5ver with a lift could cause the rear leaf springs on your 5ver to become "fatigued" as alot more weight of the camper will be on that rear axle. Heartland "Bighorn" 5vers already have this problem... researching on their forum.
But
It will probably depend on a few circumstances.
How far do you plan on going, and how much traveling you plan on doing. Also what kind of pin weight does your 5ver have verses what the new springs on the lift kit are rated for... that will all come into play.
2011 6.7L F350 DRW CrewCab
Our adventures,
Ren is offline
post #3 of 10 Old 01-10-2011, 06:13 AM
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
i wouldnt lift it like ren said the trails tend to sway back an forth because they cant sit right on the hitch, just an all around bad idea to jack ur truck up an tow
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
post #4 of 10 Old 01-10-2011, 07:22 AM
What if he were to lift the 5th Wheel equally with the truck?
91Terminator is offline
post #5 of 10 Old 01-10-2011, 08:00 AM
Ren
Ren's Avatar
Yep.. you can do that. Alot of guys do it, but most of the time its just a couple inches if that. Its sometimes needed for even stock height trucks.
Most of the time, and depending on the design of the 5ver you can run the leaf springs over the axles and that will help bring it up a little bit. I dont know how to do 8 inches tho. Your local fab / weld shop would be able to look and help. Probably taller shackles to start and taller springs to help. Maybee some airbags???
Mor/Ryde is pretty much the leader in RV suspension systems.. but they are pretty pricey. They could maybee offer some advice.
Id be careful going to high though. I dont know how it will effect the towing characteristics of the trailer.
Our adventures,
Ren is offline
post #6 of 10 Old 01-10-2011, 01:51 PM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
You can run 37" with a 4.5" Pure Performance 4 link kit..tows nicer also with the Deaver rear mini spring packs..PM me if I can get you info..
Cary
CT Performance, Inc. is offline
post #7 of 10 Old 01-10-2011, 05:04 PM
Joe 6.7's Avatar
I have a 4" and 35s on mine. I tow a 37' 5ther with no prob. Trailer has axles fliped so it rides level.
Joe 6.7 is offline
post #8 of 10 Old 01-12-2011, 07:34 AM
topdwg's Avatar
Well my truck isn't a 2011, but I do tow a 5th wheel and both my truck and camper are lifted. It can be done safely. Before I even decided to lift my camper I contacted Lippert and asked what they recommended. To make a long story short they sent me plans on how to do so and I took my truck to a friend who in my eyes is one hell of a welder. The end result is what's seen in the pic. It's still a bit high in the front, but I can still do some adjustments to bring it down. It pulls great, straight as an arrow and it's been pulled over...
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #9 of 10 Old 01-12-2011, 07:44 AM
Ren
Ren's Avatar
Looking good man! Now all you need is some mud tires on the 5ver to match the truck!
I think this is the most important. I took my truck to a friend who in my eyes is one hell of a welder
Our adventures,
Ren is offline
post #10 of 10 Old 01-12-2011, 07:59 AM
topdwg's Avatar
Yea, I need to up the tire size, that way it want look awkward...
topdwg is offline
