4x4 mode! - Ford Powerstroke Diesel Forum
post #1 of 28 Old 01-04-2011, 09:38 AM Thread Starter
ups 6.0's Avatar
4x4 mode!
This is my first 4x4 so...sorry
OK! when i'm in a 4x4-hi mode and making a slow turn the steering seems to want to pull a little back and foward!(on a dry pavement) Is that normal? And when I'm moving around 30-40 mph and clicking in to 4x4 I can hear it getting in to a 4x4 mode(not loud but I can hear it)Is that normal??
Or should I be at a stand still to shift in 4x4 ?
Thanks
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #2 of 28 Old 01-04-2011, 09:50 AM
kylev90's Avatar
Quoted: 4 Post(s)
the jumping in the stearing wheel is normal, just binding in the u-joints when turning sharply. You should never put the truck in 4x4 while moving and in drive. At least slip it into nuetral while moving, engage it, then go back to drive. Have fun
1997 CC SB. Stage 1s, 17*hpop, S&B CAI. 4" straight pipe, TW tunes, zf5 swap
kylev90 is offline
post #3 of 28 Old 01-04-2011, 09:52 AM
kylev90's Avatar
Quoted: 4 Post(s)
OH and just to add, its a bad idea to have her locked in 4x4 on dry pavement (especially turning). Thats when everything gets way too bound up and you break something.
kylev90 is offline
post #4 of 28 Old 01-04-2011, 09:56 AM Thread Starter
ups 6.0's Avatar
OK...will do!
Thanks for your replys
ups 6.0 is offline
post #5 of 28 Old 01-04-2011, 09:57 AM
Goose350's Avatar
It is perfectly fine to shift into 4x4 while driving. That's the whole point of shift on the fly.
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #6 of 28 Old 01-04-2011, 10:02 AM
kylev90's Avatar
Quoted: 4 Post(s)
I just figured it would be quite a bit of pressure on the transfer case.
kylev90 is offline
post #7 of 28 Old 01-04-2011, 10:16 AM Thread Starter
ups 6.0's Avatar
I just feel funny to be able to hear it shift! Everything is so so quite!
ups 6.0 is offline
post #8 of 28 Old 01-04-2011, 10:22 AM
It is OK to shift on the fly as long as you are not spinning the wheels when you do it. All four wheels need to be turning at the same speed.
When you shift into 4WD you are locking the front wheels to the rear wheels. If one end is turning, the other end will too.
NOW - think about this, , , in a straight line all four wheels turn at the same speed. Locking all wheels together causes no problem in this situation.
When you turn, the front wheels must travel further than the rears do. Just look at your tracks from a turn. See how the front wheels had to go out around the rear tracks?? So when you turn, all four wheels no longer turn at the same speed because the fronts had to go more distance to make the turn. If you are locked in 4WD and make a turn, you feel the wheel shimmy as the wheels try to turn at the same speed. This puts tremendous pressure on the transfer case and the diffs if you are on a hard surface with good traction. You can breaks a lot of parts running around in 4WD on good traction.
If you are on snow or in sand or something even slicker, then it would be OK to drive in 4WD and make turns as the wheels can slip easily on the turns and not put a lot of pressure on the gear cases.
One last comment - - - did you have any trouble finding your white truck in that snow????? Nice pic. I'm in Las Vegas and we had that stuff yesterday, but it's gone now.
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #9 of 28 Old 01-04-2011, 04:13 PM Thread Starter
ups 6.0's Avatar
Thanks Mowdocs for the explination
No we didn't have any problems finding our truck cuz we were the only one up there even before the plow
The pics was taken yesterday in the Palmdale hills area in the california high desert at 3000 ft.
ups 6.0 is offline
post #10 of 28 Old 01-04-2011, 08:08 PM
richc22a's Avatar
It's called 'crabbing'... perfectly normal, better traction, more pronounced..I wonder... .(a Porsche 911 all wheel drive, would it crab...?)
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
