ride quality of 250 vs 350 unloaded - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-31-2010, 03:56 PM Thread Starter
Compared to the 250's I had driven my 350 seems to have a harsher ride when empty.
Specs on my truck- SRW,standard 350 suspension with 11,500 rating, 20" wheels, FX4 cc sb.
The question I can't seem to answer is: would a 250 with camper package have the same front and rear springs as a standard suspension 350. Looked at neighbors 250 with camp package and could not tell a difference visually besides the rear block height. Is the actual front coil spring and rear 3 spring pack heavier or do they just add the overload to it? Is there any specs on the spring rating?
__________________
2011 350 CC SB SRW FX4 Lariat 6.7
2006 CC,SB 6.0 4x4 auto,lariat--gone
agr1592 is offline
post #2 of 5 Old 01-01-2011, 06:51 AM
TW720HVY's Avatar
Quoted: 2 Post(s)
I do not know if this will help. My friend and I both have the F- 350 mine is a short bed his is long.
He hates his ride as well and he has the camper and plow packages. The first night I got mine home I was reading the spring part numbers and we have different front and rear springs.
So I would venture to answer question they do not have the same springs since our two F-350s do not.
If you are in close with the parts department they can get a ton of comparison information off the VIN numbers.
Hope this helps.
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #3 of 5 Old 01-01-2011, 07:48 AM
I was posting a lot of questions on other forums trying to nail down the differences between the F250 vs F350. When I test drove the trucks back to back they rode the same to me. I confirmed the by asking about the rear springs. The only difference in the rear is the taller block and the overload.
When you put the camper package on the F250 you get the same overload (also a sway bar) but no rear F350 block. As for the front end I was told it is the exact same. There are other differences with the F350 but it is not suspension related.
rcklnhunter is offline
post #4 of 5 Old 01-01-2011, 07:51 AM
Forgot to mention. When you start comparing trucks with the FX4 or camper package the also indicate a 1 up computer selected front suspension. At least I think that's how it's worded. At any rate the front end is the same as long as you are comparing a truck with the same packages.
post #5 of 5 Old 01-02-2011, 10:02 AM
mor4wd's Avatar
Not too sure about the springs, but my '11 F350 is a LWB with SRW and the camper package. It rides a thousand times better than my 08 SWB F250. I think ride quality has a lot to do with wheelbase.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
