1st Tow With My New 2011 F-350 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-30-2010, 03:25 PM Thread Starter
Racerxray1's Avatar
I finally got my toy hauler hitched up to my 2011 F-350 (Lariat, CC, 4X4, DRW) and towed it out to the desert. All I can say is WOW!!!! It was hard to wipe the smile of satisfaction off my face. The toy hauler weighs in at about 18K lbs and the truck had all the power I needed. In fact, I never had to bury the pedal to get it up the Cajon Pass. It flew up at 60 MPH and probably could have gone faster had I wanted to. In my old truck (06 F-250), I would have been lucky to crest the pass at 40 MPH. The only minor disappointment was the exhaust brake in tow/haul mode. I never felt it and had to use the brakes 4 times to keep my speed at 55. I say this was a minor disappointment because the new truck still performed better than my old truck. Overall, I think my new truck ROCKS!!!
Racerxray1 is offline
post #2 of 11 Old 12-30-2010, 04:00 PM
The exhaust brake only works in tow/haul and you need to put your foot on the brake and only then does it kick in. I pull 25K plus and no complaints on power.
jimchris is offline
post #3 of 11 Old 12-30-2010, 04:20 PM
YodersStrokin96's Avatar
awesome!! glad your happy
--->Zach<---
1996 CCLB, XLT PSD, 4x4,
Auto, Autometer Guages, Matts Tunes, Stage 1's, AIS Water/Meth, Intake/Intercooler,
D66, gutted EBPV, Built Tran. dual napa Tran. Cooler and . . . More
1995 Ranger XL 2.3L 2x4
More Photos -->
YodersStrokin96 is offline
post #4 of 11 Old 12-30-2010, 05:42 PM
twin200's Avatar
yes,the new fords are awesome.I bought the 350 cc srw,but I never knew the fuel cell was only 26 gallons,big disappointment. My 2000 350 dually has a 38 gallon tank with a 600 mile range between pumps(not towing).Does anyone know if the fuel cell can be changed for a larger one
twin200 is offline
post #5 of 11 Old 12-30-2010, 06:12 PM
Twin200: Yes there are tanks out there that you can get for your truck that are larger. I believe Titan sells the majority of them. So check them out. Also there is supposed to be an update to the 2011's come next month that will re-calculate your fuel to empty after you put the larger tank on, so that all the gauges are correct
tbaker00 is offline
post #6 of 11 Old 12-30-2010, 06:19 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
dhanna6powerstroke is offline
post #7 of 11 Old 12-31-2010, 05:08 AM
GPD270's Avatar
Can you tell me what your MPG's are towing your hauler? I have a 40 foot 5'er that weighs in at about 18k when its loaded. My 2010 DRW F-350 gets about 8ish at 65 MPH. It is stock. I have the 4:10s. I realize that 8 is not all that bad when towing that much weight. Wish I could get 10 or so.
2010 F-350 DRW
4" MPRB turbo back exhaust. DPF delete
S&B cold air intake
H&S Mini Max
2006 F-350 DRW(sold)
4" MPRB turbo back exhaust with the kitty delete
AFE stage 2 cold air intake
Quadzilla gauges
SCT tuner with a few tunes
ARP headstuds
GPD270 is offline
post #8 of 11 Old 12-31-2010, 07:24 AM Thread Starter
Racerxray1's Avatar
MPG results for 1st Tow
I got 8.8 MPG overall. I was impressed because my 06 F-250 only did 7.3 MPG on the same run. The truck only has 2500 miles on it so I know it will only get better.
post #9 of 11 Old 12-31-2010, 07:32 AM Thread Starter
Racerxray1's Avatar
Originally Posted by dhanna6powerstroke View Post
Not a great picture but something to look at none the less.
Name:	1st Trip with Da New Truck.jpg
post #10 of 11 Old 01-01-2011, 09:06 AM
GPD270's Avatar
Thanks...yeah it should get a little better as you put more miles on her.
2010 F-350 DRW
S&B cold air intake
H&S Mini Max
Quadzilla gauges
ARP headstuds
GPD270 is offline
