Was I Just Imagining This.... Tow/Haul Mode? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-30-2010, 07:53 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
I thought the last time I had my trailer hooked up the truck/transmission stayed in Tow/Haul mode during shutdowns and restarts.
The last time I had the trailer hooked up it did not.
I could have sworn that the truck knew the tailer was still connected and kept the Tow/Haul on. Must be loosing my mind!
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #2 of 9 Old 12-30-2010, 08:20 AM
You must be thinking of something else. My truck requires the tow switch each time I start the engine. It was this way before and after the reflash.
Before the reflash, I had to engage the "gear indicator" in the disply on every start. Since the reflash the display remembers the last setting. Maybe you are thinking about this??
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #3 of 9 Old 12-30-2010, 08:26 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
I must have been... I checked with my friend who has one as well that tows and he hasn't seen this either.
Maybe because the truck is so quite I thought it was off.
Previously Owned
TW720HVY is offline
post #4 of 9 Old 01-03-2011, 01:42 PM
I must not have the reflash then. Because the only way I see the gear indicatior is if I hit the plus button on the shifter.
Might have to bring it in for the reflash.
bajasst is offline
post #5 of 9 Old 01-04-2011, 11:28 AM
Yep, you want the reflash. Not much seat of the pants power increase but you will love what they did with the transmission!!!
BedRug liner
mowdoc is offline
post #6 of 9 Old 01-04-2011, 09:15 PM
richc22a's Avatar
Minds are over rated, life is better since I let mine go... I transferred ALL decisions to an extremity using the Tiger Wood/ Brett Favre method...
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #7 of 9 Old 08-31-2011, 05:04 PM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
OK I WASN'T IMAGINING THINGS!!!!
I have finally figured it out. The "Tow Haul" mode will engaged after shutting down the engine and starting it back up. I know I wasn't crazy!
This is what I learned...
The "Tow Haul" will come on automatically with engine start as long as it was in T/H mode at shut down and either the Parking or Head Lights are on, Hazard Lights are on or the door is left open. Somehow the T/H mode is getting power or sensing from the truck's lights. It has nothing to to do with a trailer being plugged in, it does it with and without a trailer connected.
Give this a try and let me know if my truck is not the only one that does this.
Previously Owned
TW720HVY is offline
post #8 of 9 Old 08-31-2011, 06:50 PM
Quoted: 13 Post(s)
I've noticed that my tow haul stays sometime, and had wondered why. I frequently back in, unhook trailer and drive off. While the truck may be shut off when i do this, the door is frequenty left open. Hmmm?
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #9 of 9 Old 08-31-2011, 07:34 PM
That's crazy. Twice before I shut off my truck and started again, after driving for a minute realized I forgot to turn T/H back on and looked down and it was already on.
I'll give those a shot and see what happens, thanks for the tip.
2011 F-350, 5% on sides back and eyebrow-35% on windsheild, B&W hitch, Weather Tech mats, Tailgate Assist, Hornblaster Conductor Special 240, Toyo M/T 35", Incubus Krawler 20x9, 2.5" ready lift stage 3.
cdrracing is offline
