Anyone Else Pissing Diesel While Re-Fueling - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-09-2010, 03:25 PM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
I am curious to know if anyone else other than my friend and I are having problems at the end of re-fueling?
Only filled it up three time so far using "auto" and not "otr" nozzles and each time about 1/4 to 1/2 cup of fuel pissed out all over the truck and ground. The last time I even had the pump set on the lowest click and it still did it.
I cannot imagine the EPA would be too pleased about this taking place every time a 2011 6.7 re-fueled. It seems the filler neck is fairly flat and when the tank tops off it has nowhere to go but out.
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #2 of 17 Old 12-09-2010, 04:53 PM
colfaxent's Avatar
A friend of mine has new 6.7 with same issue and the local Ford dealer is replacing the fuel tank tommorow , I willl follow up to let you know how he makes out. JIM
2009 F350 Crew Cab
H&S Black Maxx Tuner
S&B Intake
2010 Cameo 36FWS 5TH Wheel
Hellwig Sway Bar
MBRP Cold Side Pipe
Closed system CCV mod
5160 Bilstiens x4
Icon 2.5 Front springs
PMF Floating Traction blocks and bars.
PMF Dual Steering Stabilizer
colfaxent is offline
post #3 of 17 Old 12-09-2010, 05:54 PM
Yeah mine does it occasionally. You can't top it off unless you really baby it.
pipeliner08 is offline
post #4 of 17 Old 12-09-2010, 06:23 PM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
Wow... I figured it would be a filler tube issue and not a tank issue. But please let me know how he makes out and if it fixes the problem.
Previously Owned
TW720HVY is offline
post #5 of 17 Old 12-09-2010, 06:36 PM
what mpg are you getting 6.7 towing
trying to decide between 6.2 gas 6.7 diesel i have 6.0 now miss my 7.3 would appreciate real info thanks
baywest is offline
post #6 of 17 Old 12-10-2010, 05:42 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
colfaxent, can try and find out from your friend why they decided to change out the tank. I am wondering what they changed if anything on the internals of the tank and/or plumbing.
Thanks!!
Previously Owned
TW720HVY is offline
post #7 of 17 Old 12-10-2010, 03:52 PM
I have quite a few fill ups now but haven't had any spillage. Definitely curious if it is an issue with design.
2011 F-250 XLT Crew Cab 4x4 - Sold
Hideaway Gooseneck Hitch to pull my Longhorns!
Access TonnoSport Removable Bed Cover
2006 F-250 XLT Crew Cab 4x4 - Traded
Banks 6 Gun Programmer
4" Turbo back exhaust
EGR Delete
jflow730 is offline
post #8 of 17 Old 12-11-2010, 02:20 PM
mc5150's Avatar
I've never had that problem. ??
2011 F350 Lariat CC SB 6.7L
Previous: 2008 F350 King Ranch CC SB 6.4L
mc5150 is offline
post #9 of 17 Old 12-12-2010, 06:35 AM Thread Starter
TW720HVY's Avatar
Quoted: 2 Post(s)
Interesting... are you guys that are not having this problem allowing the pump to auto shut off or are you turning it off when you hear the fuel starting to gurgle?
Previously Owned
TW720HVY is offline
post #10 of 17 Old 12-12-2010, 09:52 AM
Refilled mine last night and was curious if I could duplicate what others on here were having problems with. I put the latch down and let it run until it clicked off, no problems. I held the handle wide open to try and top it off again and it had a little spillage then. Less than 1/2 cup probably
Normally when I top it off I hold the handle about halfway down with no problems. So I guess I did see how it happens but not unlike I have had with other trucks.
Hope that helps.
EGR Delete
jflow730 is offline
