fuel filter housing - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-07-2010, 08:29 AM Thread Starter
fuel filter housing
I called my dealer about changing the fuel filters and ask if there was a recall on the housing because of breaking when being removed. He said ford wants the housing replaced with a filter change but wasn't sure what part they are referring to. He quoted a price of $157.23 for changing filters but not including a new housing. Anyone else hear of this. My concern is if i am traveling and need it changed and it breaks and no parts available. Also if i change filters myself who pays for the housing.
mlsjohn is offline
post #2 of 13 Old 12-08-2010, 03:38 AM
I changed mine & used the 32MM socket per directions. When i went to take off the plastic nut broke off the housing without much force. I called around to every dealer in my area & no one stocked the part. Finally found one in New Mexico & had it shipped to me. I did epoxy the nut back onto the housing but it is now leaking some.. Will have to replace it. If you remove the housing use a 24" pipe wrench or a strap wrench.
09stroker is offline
post #3 of 13 Old 12-08-2010, 04:38 AM Thread Starter
Will a strap wrench unscrew it without breaking it from the frame or do i need to remove from the frame first? thanks john
mlsjohn is offline
post #4 of 13 Old 12-08-2010, 04:48 AM
A word to the wise, purchase one before you work on changing any of the filters oil or fuel.
I purchased all 3 for the just incase so will not need to get a taxi, bike, walk or need to rent a way to get to and or work due to a broken part that needs to be removed for required services.
It is cheep insurance.
DieselFord is offline
post #5 of 13 Old 12-08-2010, 01:29 PM
After i broke off the plastic nut i used a 24" pipe wrench to get the housing off, next time i'am going to try & use a strap wrench. I don't see any reason why it won't work. I think Ford needs to re design the housing to something better....
post #6 of 13 Old 01-04-2011, 10:14 PM
DieselFord got the three housings from me. I happened to purchase a "lot" of them to help people avoid the high prices at the dealer, but I have a question. One person bought one from me and said they have a "banjo" type fitting on their fuel line, and the fuel fitting in the revised housing that I have is larger. They have an early 6.0, and the dealer claims he doesn't know anything about a different fitting but was glad to offer to sell them "another" housing...
DieselFord, did you have any issues with the fuel lines on your trucks? Thanks guys, LMK if anybody needs a housing.
laserred is offline
post #7 of 13 Old 01-05-2011, 07:05 PM
richc22a's Avatar
I had my oil and filter changed here in Phoenix. They broke the filter cap and cannibalized a new truck to get me rolling.... Appreciate the heads up on the item...
The shop where I bought the truck did a filter change w/o a problem....
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #8 of 13 Old 01-05-2011, 07:47 PM
Sanderson Ford ? They have the largest stock of truck parts in southwest.
post #9 of 13 Old 01-07-2011, 05:16 AM
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
Any pix of this? I am a visual person ....
TX_TRU_STUD is offline
post #10 of 13 Old 01-08-2011, 06:34 PM
TX Stud, sent you a PM...
laserred is offline
