Ride potential - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-28-2010, 05:25 PM Thread Starter
Ride potential
I have severe back problems, and these become worse when ridings in a stiff riding truck. Since my truck has the Lariet pakcage on the inside the seats are very nice, but being a 3/4 ton the ride can be stiff and a little rough at times. What I'm thinking of are air bag suspension on the rear. Why only rear on might ask, and I answere because I'm conservative. There is plent of weight on the front, but the back is light and the softer suspension there would be off most help to the ride. At least, in my mind. Any comments or suggestions? I have the partial fx4 package and wonder if the shocks are stiffer on my package, perhaps this is all I need to change?
Rich
64 f100 is offline
post #2 of 7 Old 12-03-2010, 06:47 PM
i have airbags on mine, it won't help make the ride softer when you're empty...they do help a lot with a heavy load to reduce the recoil and compression of a bumpy road.....dodge has the option of reducing the air pressure in the rear tires to 45 lbs and not set off the tps...but ford does not....i reduce the tire pressure on mine when i'm empty, everything works fine....i get the warning whenever i start the engine, but i just press reset on the dash and forget it..
slyrydr is offline
post #3 of 7 Old 12-03-2010, 06:57 PM
swamp_ratt's Avatar
air bags will make it ride worse. your best bet would be to 4 link your rear end and do coil overs. thats about the best your going to do. you could also take a spring or 2 off the pack and have em re-arched and see what that does ya. i dont know how many springs the super dutys have on the rear packs. if there is only 4 leaves, only remove 1 on each side
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #4 of 7 Old 12-03-2010, 08:31 PM
ups 6.0's Avatar
I have a set of rear Bilsteins coming monday and I'll let you know.
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #5 of 7 Old 12-04-2010, 06:10 PM
richc22a's Avatar
I have had a few issues with my back, running the heated seats(increases blood flow/circulation), and a little lumbar has made a huge difference. A little off your post, a buddy has had issues also, since running heated seats he swears by em... good luck
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #6 of 7 Old 12-05-2010, 06:12 AM Thread Starter
I run the air conditioning on my seats, most times. Ice does me a lot of good when I'm at home. I do also run the heat when I feel it helps. Both are a godsend, but nothing cures my back problem.
I went to Louisville yesterday, pulling my car trailer, running at or between 65 and 70. Fuel mileage droped like a stone. On the way back, filled up and ran interstate nearly all the way. Verying speeds tosee if things got better or worse. If, I drove 50 to 55 it went up to about 14.1 mpg, at 60 to 65 about 13.9 and did not seem tomake it much worse when going 70. On the way back, I had a cab, bed and front end on the trailer. I also had two hoods, and two bumpers in the bed of the truck. The parts were form a 66 shortbed.
I was stove up by the time I got home from driving 6 hours plus adn loading up parts.
Rich
64 f100 is offline
post #7 of 7 Old 12-05-2010, 10:55 AM
New Tires
Rich
I have summarily back problems and my new truck came with Continental Tires which are very stiff tires and felt every bump. I just installed a set of new Michelin M/S tires.. Now the ride is greatly improved and much more enjoyable ride. I now have 4750 miles on my F-250 4X2 Truck. I bought my new set of tires from "Discount Tire" because they will let you try them out for a few days and see if you like them... I have used Michelin Tires for years on my Trucks without any problems, must of my driving in Hwy driving... With Michelin's you have to drive them for a few days to soften them up, they just keep getting better as I put miles on them:....icon_ford:
Thanks
Don
djc1208 is offline
