Leveling kit for F350 4x4 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-24-2010, 11:41 AM Thread Starter
ups 6.0's Avatar
I'm considering doing the leveling kit on my 2011 F350 ....I found these on E-bay.Let me know what you guys think?
2005-2011 FORD F-250/F-350/450 2-1/2" Lift Leveling kit: eBay Motors (item 130436258165 end time Oct-26-10 17:14:01 PDT)
Also ...whats pros and cons about leveling it?
Thanks guys(beside the looks)
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #2 of 5 Old 10-25-2010, 11:46 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Your link doesn't work but that lift is a spacer lift and while it will lift your truck it doesn't address the axle shift that will happen or the loss of Castor from the lift...
CT Performance, Inc. is offline
post #3 of 5 Old 10-26-2010, 04:38 PM
Cary,
Can you explain more a bout the axle shift and the loss of castor? Also, have you ever hear of anybody putting the dually (2") blocks in a SRW 350 to get the rear lower. Would have that the same problems?
Thanks,
BrutusIII is offline
post #4 of 5 Old 10-27-2010, 09:20 AM
Quoted: 3 Post(s)
Changing the rear blocks shouldn't cause any problems just make sure your shocks don't bottom out.
The front end when it cycles allows Castor change as it pivots from the end of the radius arm. Lifting it reduces the castor thats why most manufactors provide a Castor ball joint shim to get back to stock castor with a level kit.
The axles in SD's have a track bar and this keeps the axle centered at ride height, when lifted the axle shifts since the relationship of the suspension is like a tringangle..geometry ..change 1 leg it affects the others so to keep the axle in its correct location the track bar needs to be longer..or a correct drop bracket for the exact lift your installing.
post #5 of 5 Old 10-27-2010, 09:45 AM Thread Starter
ups 6.0's Avatar
Thank you Cary
ups 6.0 is offline
