Ford 5th Wheel Prep Package for SB - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-21-2010, 03:09 PM Thread Starter
Superduty123's Avatar
With Job2 Ford has released the 5th wheel hitch for the Shortbed
I wanted to add it to my order but the dealer is telling me not to as it is only good if you buy a Ford Specific 5th wheel hitch
I don't have a 5th yet, only thinking about getting one. But the prep package seemed like a good idea with the bracing bar they put underneath
For those of you who do ahve a 5th wheel, or the Long bed with the prep package, is it worth it?
Superduty123 is offline
post #2 of 7 Old 10-21-2010, 06:09 PM
MDarrough's Avatar
Quoted: 2 Post(s)
Most definitely worth it!! I love it!! I did buy the Ford hitch and love it too!! But you DO NOT have to use the Ford hitch with it. The hitch AND the rail kit under the bed are BOTH made by Reese. So, you can get a Reese signature hitch and a mounting kit so it works with the prep package. That would probably cost about half of the Ford/Reese hitch. I hear they are hard to find right now, but I don't know for sure.
I worked the Ford hitch in as part of the deal on my truck and got it for $1200 (normally about $2800). Even if you don't end up getting a 5er, the prep package would certainly add to the resale value of your truck
It is a massive heavy duty hitch. Here's mine installed.
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #3 of 7 Old 10-21-2010, 07:38 PM Thread Starter
Nice looking set up
When the hitch is out, are there plugs for the holes?, is the bed completely flat?
post #4 of 7 Old 10-21-2010, 07:40 PM Thread Starter
oh, and one more question. How does it actually mount, do you have to get under the truck to tighten it down?
post #5 of 7 Old 10-22-2010, 10:18 AM
MDarrough's Avatar
Quoted: 2 Post(s)
Yes, the bed is flat with the hole covers in place. The one in the middle is for the gooseneck ball, and the four for the 5er hitch look the same only smaller.
To mount, just stab the four corner posts in the holes, then there are four "arms" on the bottom of the hitch that turn outward to lock it in place.
Maybe this will explain better than me. LINK
Mark
post #6 of 7 Old 10-22-2010, 04:22 PM
Porthole's Avatar
If you plan on towing a 5th wheel or goose neck I absolutely would at least order the prep package.
As mentioned above, it is a Reese mount, of which many hitches will fit.
I'm planning on a Trailer Saver hitch for my truck. Here is a video showing how it mounts. Other hitches will be similar.
Thanks,
Duane
First ever blue oval........
2011 F-350 DRW White Tri-coat
2010 3010 Cyclone Toy Hauler
Porthole is offline
post #7 of 7 Old 10-22-2010, 05:07 PM Thread Starter
I ordered my truck today with the prep package
Thanks for all the info
