Best Additive? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-09-2010, 11:50 PM Thread Starter
IFlyEm's Avatar
Best Additive?
Whats the consensus on the best cetane booster for the 6.7? My Ford dealer is adamant that I need to run a booster and sold me some Motorcraft stuff. Is there a better option?
Diesel Kleen® +Cetane Boost® in the summer and Diesel Fuel Supplement® +Cetane Boost® in the winter?
IFlyEm is offline
post #2 of 6 Old 10-11-2010, 12:38 PM
I use the Ford product but at higher concentrations so if there is ever a fuel system issue the additive can't be "blamed". I haven't tried Opti-lube but may soon.
BlueF350 is offline
post #3 of 6 Old 10-11-2010, 01:47 PM
ups 6.0's Avatar
Why would you need an additive
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #4 of 6 Old 10-11-2010, 03:27 PM
The genius within the EPA decided it was in everyone's best interest to reduce the sulpher content in diesel fuel to a maximum of 5 ppm. Sulpher acts as a lubricant in your injection pump and lubricates your injectors. A diesel fuel additive restores some of that lost lubricity and also acts to reduce the cloud point of diesel fuel in cold climates. Other benefits include absorbing water and inhibiting algae growth in warmer climates and increasing the cetane level of the fuel (similiar to the effects of tetraethyl lead in gasoline.) Personally I use Schaeffer's Diesel Fuel Additive. Schaeffer Oil Videos.com :: St. Louis, Missouri - Videos
You'll find that alot of people here use different brands, the main thing is to start using one with every tank fill up.
Hope this helps.
Leer Canopy
Line-X Bedliner
DieselSite Coolant Filter
Amsoil By Pass Oil Filter
Schaeffer's Fully Synthetic 5W-40
MBRP 4" Turbo Back with CAT Delete
Bullet Proof Diesel Oil Cooler & EGR Cooler
SCT TSX Tow Tune + 50 H.P.
Pyrometer
MountainMan is offline
post #5 of 6 Old 10-11-2010, 05:41 PM
I have 14 diesel engines from 1953-2011 and I run B-11 in all of them. The only time I use an additive if its going to be below 10 degrees.
jimchris is offline
post #6 of 6 Old 10-11-2010, 07:04 PM
biscuit's Avatar
EPA motto, "We're not happy untill your not happy"
There are several other goverment agencies that use this motto
biscuit is offline
