FM Antenna height - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-29-2010, 08:50 AM Thread Starter
jdkinzenbaw's Avatar
FM Antenna height
Guys,
Do you know of any companies that make good aftermarket FM antennas for our new trucks? Every time I go into my garage, my FM antenna bends really far... unfortunately the top of my truck comes within two inches of the height opening on my garage, and that means the antenna hits several inches below the top.
I just want to take it off and put a shorter one on, but I don't want to lose reception.
Any ideas or thoughts?
PS - I still need to get pictures up of my truck. Sorry about that... hopefully will have an opportunity before long.
2011 F250 CC SB KR Black/Adobe
H&S Black Maxx, EGR Delete, DPF/DEF Deleted exhaust
Line-X'ed DiamondBack ATV Cover
295/20 TerraGrapplers, XD Spy's
AMP power steps
50-gal TransferFlow tank
B&W Turnover Ball w/ Companion Hitch
Firestone Air Springs - front and rear
ViAir Xtreme Duty air system
Kleinn Train Horns
2012 Heartland Road Warrior 30C 5th-Wheel Toyhauler
2 Can-Am Quads that go everywhere the TH goes!
jdkinzenbaw is offline
post #2 of 20 Old 09-29-2010, 08:58 AM
SuperCrutyPS's Avatar
Quoted: 333 Post(s)
Garage
I put a Stubbie 21" antenna on my truck. It is made by AMI. (Do a google search) - I had the same issue. I was always taking off my stock antenna to get the nose in the garage.
I don't remember where I bought, but it works good.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 20 Old 09-29-2010, 09:16 AM Thread Starter
Will do - I'll check on that. Thanks for the input. Hopefully I can find something good.
No FM coverage issues after doing that eh? i was hoping that a shorter antenna wouldn't shorten reception. One of my favorite stations sometimes comes in a little weak where I live. Granted, I've got Sirius in there, but sometimes I like the local stuff too.
AMP power steps
Kleinn Train Horns
post #4 of 20 Old 09-29-2010, 10:42 AM
I had the same problem. Took mine off and cut it down by the base. I drilled the base with a masonry bit due to the hardness of the steel used, cut stem to desired length then welded it back up.
pipeliner08 is offline
post #5 of 20 Old 09-29-2010, 11:28 AM Thread Starter
Alright. Good deal... wonder why they make those so tall? I suppose it's for better reception, just kind of frustrating when you pull in a 7' parking garage and clear everything else, only to have to listen to the 'tick tick tick' of your antenna slapping on the concrete ceiling dividers above you... not to mention every one of those exit signs and wire conduits...
AMP power steps
Kleinn Train Horns
post #6 of 20 Old 09-29-2010, 11:29 AM Thread Starter
Done! I ordered it from JC Whitney. And while I was at it, ordering a $30 FM Antenna, I decided to order a $400 train horn kit. Good thing I needed that $30 antenna, or I'd have never found a way to spend that other $400. HA!
I guess this is the manly version of "accessorizing"... Ha!
AMP power steps
Kleinn Train Horns
post #7 of 20 Old 09-29-2010, 11:35 AM
Quoted: 333 Post(s)
Garage
- One will help you GET noise, the other one will help you MAKE noise!!!
Nicely done, Sir!!!!
My Truck Garage:
Tow Toy Garage :
post #8 of 20 Old 09-29-2010, 12:03 PM Thread Starter
I'm thinking I should just cut up my credit card. And then, again, I've used it so much lately, that I realized I now have the number memorized. Dang it!!
Can I call the bank and tell them that I've stolen my own credit card??
AMP power steps
Kleinn Train Horns
post #9 of 20 Old 09-29-2010, 08:33 PM
ups 6.0's Avatar
I need one too! Do you have part #?
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #10 of 20 Old 09-30-2010, 05:35 AM Thread Starter
Well, I don't have a part number, but here's the information from my JC Whitney order confirmation. I think you should be able to at least find it on JC Whitney's site with that help. I just ordered the 21" black powder one. It apparently comes with several adapters to fit various antenna bolt sizes.
ANTENNA 21" BLACK POWDER
Item Number:268046
Quantity 1
Unit price: $32.99
AMP power steps
Kleinn Train Horns
