High Idle Mod - Ford Powerstroke Diesel Forum
post #1 of 46 Old 09-27-2010, 01:29 PM Thread Starter
shook08's Avatar
High Idle Mod
Just bought a 2011, had a 2005 with high idle mod loved it, can this be done on the 2011 with upfitter switches.
shook08 is offline
post #2 of 46 Old 09-27-2010, 02:55 PM Thread Starter
shook08's Avatar
anyone, yes, no, maybe?
shook08 is offline
post #3 of 46 Old 09-27-2010, 03:07 PM
Yes, it is the same idea but the 2011's SEIC requires a resistor to provide a voltage signal to PTO RPM whereas the 05-10 SEIC would work without a resistor/voltage signal.
https://www.fleet.ford.com/truckbbas...tml/Q180-A.pdf
jasonmt is offline
post #4 of 46 Old 09-27-2010, 08:16 PM
Do you still need the resistor if you're using BCP instead of the PTO mode?
nhunter is offline
post #5 of 46 Old 09-27-2010, 08:32 PM
On page 3/9 of the linked .pdf file: Input Resistor In ALL modes (SEIC, PTO, BCP), an input resistor is required. This resistor value may be obtained per table "B".
jasonmt is offline
post #6 of 46 Old 10-13-2010, 07:25 PM
Anyone know the wattage of the resistor. The Source had a 22,000ohm resistor availabe in 1/8 and 1/4 watt. Or am I barking up the wrong tree totally?
nhunter is offline
post #7 of 46 Old 10-19-2010, 12:26 PM
Porthole's Avatar
Idle up is a factory option on the GM's. This is great that it will be a relatively simple procedure to get idle control on the new trucks.
Porthole is offline
post #8 of 46 Old 10-19-2010, 03:30 PM
Neat and the fact that I ordered upfitter switches makes this relatively easy... Although hopefully I can find the correct resistor. A neat mod may be to use a rheastat to set the resistance level, this way you can SEIC at whatever RPM you want at a given time. Rather than limited to just the one level of a single resistor.
Dakster is offline
post #9 of 46 Old 10-19-2010, 06:21 PM
Porthole's Avatar
Where the instruction say "POT" that is short for potentiometer, which is also known as a rheostat.
Porthole is offline
post #10 of 46 Old 10-28-2010, 12:12 PM
IFlyEm's Avatar
If I just want to hook up SEIC is it just a matter of wiring the SEIC pass through to the Upfitter switch I want to use with a resistor separating them? Or is there more to it?
IFlyEm is offline
