2011 Ford F-550 Pickup Conversion - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-05-2010, 08:04 PM Thread Starter
TapsTruckAndAuto's Avatar
Does anyone have an idea on where i can find a bed conversion or how to go about doing this? Do i have to have the shorter wheel base or can i have the long wheel base and use a spacer? Any help would be appreciated (: Thanks!
TapsTruckAndAuto is offline
post #2 of 7 Old 08-06-2010, 03:37 PM
starshockey's Avatar
Not sure what kind of bed you are wanting but there is Bob King's truck beds in Boyd, Texas. They make the beds for Western Hauler.
home
2000 F-350 CC 7.3
M&M Truck Conversions Hauler Bed
Quadzilla 4 position chip
4" Turbo Back Exhaust
Gauges
2008 F-250 CC 6.4
Bone Stock
Will order a 6.7 to replace the 2000 7.3 once the 6.7's have been in the real world about a year and they are proven.
starshockey is offline
post #3 of 7 Old 08-07-2010, 11:48 AM Thread Starter
need a pick-up bed for it. if anyone knows someone who has a used 2011 superduty bed....
post #4 of 7 Old 08-07-2010, 06:53 PM
In the past, at least for the Crew cab, the ones I have seen either had a spacer or a modified and extended bed. Unfortunately I cannot lead a direction to find the manufacturers. Maybe try searching in a 7.3 or 6.0 forum.
First_Ford is offline
post #5 of 7 Old 08-07-2010, 07:05 PM
BudDog's Avatar
Quoted: 2 Post(s)
same with the 450's Ive seen.about 2 1/2or 3 inches.
96 F350 Dually Super Cab 7.3 Stock. Now I have a Solid Mass Flywheel.
BudDog is offline
post #6 of 7 Old 08-07-2010, 07:55 PM
The company that puts these beds on is in loiusville KY, called manning equipment I think. I had one on a 05 450 I had, you have to have the 4 inch spacer in the front, the wheelbase on a chassis cab is 4 inches longer than a pickup. It was alot of work to put one on without the kit from manning, I made my own mounting kit beacuse I found a used bed with the spacer but no mounting kit,and it was a job becuase you cant set the bed down on the frame flat, It must sit up off the frame at least an inch or so int he back beacuse of the frame rails, so all your bracket s are a differant thickness becuase the front has to be down on the frame, I tried to jsut buy the kit and they wouldnt sell it back in 05, had to have them install it and that was around 5K if I remember correct.
53 willy is offline
post #7 of 7 Old 08-08-2010, 05:55 AM
muntu's Avatar
these guys build flatbeds for pickups and have stacks of beds for sale.
ALUMINUM TRUCK FLATBEDS - lightweight , save fuel, and look great! by Highway Products
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
