Plastic oil pan!?!?! - Ford Powerstroke Diesel Forum
post #1 of 29 Old 07-09-2010, 07:59 AM Thread Starter
relentless1's Avatar
Is it Just me or did anyone elses truck come with a pos plastic oil pan? What the heck is up with that nonsense.
2011 F-350 S/C Lariat
2.5" Icon Leveling kit
HID headlamps and fogs
AFE stage 2 Intake
BMF S.O.T.A Deathmetal Black 20"
Toyo Open Country MT's 35"
relentless1 is offline
post #2 of 29 Old 07-09-2010, 08:11 AM
dalton1's Avatar
nothing wrong with a plastic oil pan, wont rust or corrode like mine.
03 F-250 Lariat Crew Cab SB 6.0L Auto 4x4
5" exhaust, AFE intake, Blue spring mod, EGR Delete, 58v FICM, Warren 175/75 injectors, Powermax Turbo,
ARP Head Studs, Coolant filter, Innovative tunes
Pine Tree Powerstroke Association Director
pm me for chapter info
dalton1 is offline
post #3 of 29 Old 07-09-2010, 08:18 AM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
heck id rather have a plastic oil pan,like he said,no rust no corrsion,although i would not go in the woods with it.were would i look for a plastic oil pan? i tow,my rig never hits the dirt,all pavment,all the time,so the plastic oil pan would work for me
harley1rocker is offline
post #4 of 29 Old 07-09-2010, 08:19 AM
FordGuy100's Avatar
Plastic oil pan? Well, I guess it wont corrode, but dont try going over any large rocks without help....
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #5 of 29 Old 07-09-2010, 08:23 AM
oldtimer550's Avatar
The modern plastics are as strong or stronger than the tinfoil pans. I wouldn't even give it a second thought. IMO, it's a smart move. The damn fuel tanks should be plastic. My 2000 550 diesel's tank is rusted through in 4 places. The oil pan is tender too.
2012 F250 With 9'6" Fisher Xtreme V plow.
oldtimer550 is offline
post #6 of 29 Old 07-09-2010, 08:29 AM
FordGuy100's Avatar
I wonder how well the oil pan is letting the oil cool. Obviously thats not its purpose, it has an oil cooler to do so, an no oil pan is made as the major cooler. But I've read two posts with fairly high engine oil temps. Wonder if the plastic oil pans hold on to heat more so than steel pans.
Like I said I know they arent meant for towing, but I'm sure they cool a little bit.
Just a thought.
-Justin-
post #7 of 29 Old 07-09-2010, 05:48 PM
Aluminum would be best IMHO
All the Big diesels we have in the Wood yard have aluminum pans...
but Think about it if you got as hole you could fix it with Plastic steel,we have this were i work and its some tuff stuff....
kinda like JB weld, only for plastic
Lead Foot is offline
post #8 of 29 Old 07-09-2010, 06:01 PM
shaking things up
jethro's Avatar
plastics are really strong now i see no problem with that. my intake manifold on my ranger is plastic it should not warp like steel nor rust
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #9 of 29 Old 07-09-2010, 11:38 PM
Yeah I noticed the plastic oil pan but the tranny has a metal one. Weird, I know the new plastics are in most cases stronger then the thin metal ones. Cooling however I think with plastic would be inferior to aluminum or metal. Why metal on the tranny and plastic for the oil pan?
jacob678 is offline
post #10 of 29 Old 07-09-2010, 11:57 PM
powerhoghp's Avatar
True.... BUT they have a tendency to not seal right and blow apart if you try forced induction....
As for the plastic oil pan, plastic is more insulating than metal... Even though it is probably very strong, I wouldn't want to put one on a diesel simply from the amount of heat. Hopefully the engineers thought of this. I don't think it would stand up to rocks very well though since metal will dent before it punctures instead of fracture.
powerhoghp is offline
