Tire Pressure Monitoring Sensors in Aftermarket Wheels? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-08-2010, 02:41 PM Thread Starter
rmkhauler's Avatar
Can the TPMS sensors used in the 2011 trucks be programmed for lower than stock tire pressures? I'm about to have my 37" toyos mounted on new wheels and I'm trying to decide if its worth the cost to have the sensors pulled out of the stock wheels to use in the new ones. If I am going to get the low pressure light anyway, it seems pointless to have them.
rmkhauler is offline
post #2 of 9 Old 07-08-2010, 05:39 PM
vrsc's Avatar
I switched mine out and never had to change anything and no light
2011 F250 Golden Bronze/Arizona Beige Fully Loaded King Ranch FX4 with Navigation, 6.7 PSD, 4x4 E-locker, Color Matched Line-x Bed and toolbox, Icon Vehicle Dynamics/One Up Offroad Suspension Lift, BMF Novakaine 8 Chrome 20x10, Toyo M/T 37x13.50x20, Color matched Brake Calipers, Amp Research Steps, H+S Mini Beta, CAT/DPF delete, AFE intake and 1000 watts of JL Audio and Focal
vrsc is offline
post #3 of 9 Old 07-09-2010, 02:28 PM
i changed mine and the damn light has been off every since... took it to ford and they turned the light out.. picked it up and drove maybe 5 miles before the stupis light came back on!
realspeeded is offline
post #4 of 9 Old 07-10-2010, 05:14 PM
relentless1's Avatar
Mine comes on all the time. I've decided to just deal with it as I'm using the stock wheels & tires for winter. You'll get used to it.
2011 F-350 S/C Lariat
2.5" Icon Leveling kit
HID headlamps and fogs
AFE stage 2 Intake
BMF S.O.T.A Deathmetal Black 20"
Toyo Open Country MT's 35"
relentless1 is offline
post #5 of 9 Old 07-11-2010, 04:31 AM
Its Government mandated for all vehicle's 2008 and newer to have a TPMS. Don't you just love the Government!! That is just so stupid, do they really have nothing better to do than to mandate a silly tire pressure monitoring system be put on vehicles that only works 1/2 the time?? I HATE TPMS, so cheesy! They never work right. Besides, one of my routines before I hop in my truck is to glance over the tires, check for leaks, etc.
Strokker is offline
post #6 of 9 Old 07-11-2010, 10:01 AM
Here is Ford's take http://www.motorcraftservice.com/pub.../11f23og1e.pdf , see page 223. Obviously it isn't always impossible seeing posts above but thumbing through I thought I'd point this out!
11PSD is offline
post #7 of 9 Old 07-11-2010, 11:11 AM
Zytek_Fan's Avatar
Quoted: 40 Post(s)
The TPMS sensors are calibrated for use in the stock tires, so it might send a light if you use a different pressure in the 37s
Back to the blue oval: 08 F350 FX4 CCLB - DPF/EGR delete - Spartan tuner - S&B CAI - 4 in DP to 5 in SP
First truck: Early 99 F350 SC LB ZF6 4WD - SOLD
Zytek_Fan is offline
post #8 of 9 Old 07-11-2010, 11:38 PM
Have not figured out how the sensors work to set reference pressure for the tire.
For example a shop rotated my tires, I drove 4 miles home and then went thru the TPMS procedure in the manual to get the computer to ID which tire was where.
Interesting was I had them rotated and pressures changed at the shop, drove it home 4 miles then did the computer TPMS procedure (page 236). The 80 lbs rear tires were now 65 lbs on the front and did not set off a warning. I thought that the rear tire sensors would have been monitored by the comuter for 80 lbs and at 65 lbs would have hollered till it went thru the TPMS procedure to know the tires changed location.
During the TPMS process after rotation,the computer sure knew when I let air out and sounded the horn acknowledging that tire was at a know location.
The TPMS procedure in the manual says after the computer tells you which tire to let air out to get the sensor ID location for the computer, then air the tire back up to desired pressures, but... talks about unloaded or loaded pressures being your choice.
So I now am wondering if airing up the tire to whatever pressure after the TPMS procedure sets the monitor minimums.
It still does not explain why my tire rotation and the shop changing pressures and location did not holler in the 4 miles home.
2011 F350, PS, 4X4, CC, SB, 20' wheels, Lariat with packages: Chrome, locking axle, FX4, elect cab heater, Lariat Ultimate package, block heater, 12.5 K hitch, Bed extender, Tailgate Step, Garage Door Opener.
Les-in-AK is offline
post #9 of 9 Old 07-12-2010, 06:42 AM
Zytek_Fan's Avatar
Quoted: 40 Post(s)
They must have solved that problem then.
