14,000 miles in 2 months with an abusive streak! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 07-03-2010, 08:41 PM Thread Starter
richc22a's Avatar
I just finished a 1660 mile roadtrip pulling my 8k trailer averaging 72 mph moving time per Garmin from Mempis into Montana, with the various grades. It was a 'time was of the essence' trip, the 7-11 mpgs were the result of cruising 76-82 on flat, up grades, into 35 mph headwinds. I had a deadline, never backed out of it unless stopping for fuel, or waiting on traffic. Oil temp hit 242 , tranny temp hit 226 in 95 degree temps bucking 35 mph headwinds. Cruising up a grade (posted 6%, truck said 2%) with an 8k load was uneventful, except for the downshift to fifth. Left cruise control on 98% of the time, set at 80, it varied from 77-81 in the mountains, downshifting to pick up the mphs as needed. Overall...worked just like it was supposed to...
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #2 of 19 Old 07-06-2010, 10:46 AM
Those temps seem pretty high. Otherwise, it sounds like your 6.7 is hanging Ford tough.
BlueF350 is offline
post #3 of 19 Old 07-06-2010, 01:26 PM
Does your truck have an external tranny cooler?? Cause those temps are pretty high!! If your truck doesn't have a cooler get one put on there ASAP!! With these types of conditions I would highly recommend to change your fluid every 30-50k miles. I wouldn't go 100k like what Ford says, maybe if the temps never go over 170 degrees.
But besides that, it sounds like this new motor is definitely a performer. Wonder what the EGT's where, especially with all the emissions equipment and whatnot.
Strokker is offline
post #4 of 19 Old 07-06-2010, 02:10 PM
I thought that the SD tranmissions had external coolers? Maybe he needs a larger unit?
BlueF350 is offline
post #5 of 19 Old 07-06-2010, 08:38 PM Thread Starter
richc22a's Avatar
These trucks are designed to be work trucks, a one ton truck that is plush, still is a one ton truck. I know that I am supposed to use common sense in operating it... but that "wonder how it will hold up running hard for an extended time" question popped up!!! I watched the temps close, and when I backed out a little, the temps dropped rapidly. The truck never exhibited any hesitation, always responded when prompted. One incline, slowed for the corner at the bottom, then went wot till I hit bout 75 up the hill. I was impressed, I had a 7.3 I broke in running hard, other than maintainance, and replacing the typical items in 300k plus, it ran great until it was totalled at 340k.
I had been told by an old mechanic, 'break it in the way you want to drive it'. And the only vehicles I have ever had difficulty with were the ones I babied...
richc22a is offline
post #6 of 19 Old 07-07-2010, 03:52 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
you said you were towing, any idea what kind of weight you were hauling?
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #7 of 19 Old 07-07-2010, 04:00 AM
shhhhh, can you hear it?
08pwrstrokr6.4's Avatar
reread the post.it says 8k trailer aka 8000lbs
Patrick
TAPS Historian
08 6.4L ECSB
S&B intake,H&S Black Maxx,5" Pipe,Trac. Bars
13.77@100.63
OIF 07-08 16 months OIF 10/OND 10-11
Originally Posted by Diesel Tech Mag
All you need is a little knowledge,the right tools, and a buddy's truck to practice on.
08pwrstrokr6.4 is offline
post #8 of 19 Old 07-07-2010, 09:28 AM
Towing speeds and hilly country seem to put your truck right in the target zone........How many times have you had to add the DEF.....I have added 15-gallons in 10,000 miles.........
358ciHD is offline
post #9 of 19 Old 07-07-2010, 07:16 PM Thread Starter
richc22a's Avatar
14,000 + miles, I have added about 10 gallons, and it is under 1/2 now. I used quite a bit idling it all day when I was in the Mississippi heat...
richc22a is offline
post #10 of 19 Old 07-08-2010, 02:21 PM
MyDiesel250's Avatar
Dam that sounds sweet towing 8k with no prob. DEF is there any way to work around it?
MyDiesel250 is offline
