Air Dam - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-16-2010, 09:40 PM Thread Starter
cyarbroughjr's Avatar
Air Dam
I removed the air dam from under the front of the truck. Heard this was bad for the engine, but have had no problems...........it sure looks better!! Is there any truth to this??? I heard it could cause over heating without it?
2011 Ford F350 King Ranch Golden Bronze Loaded
cyarbroughjr is offline
post #2 of 2 Old 06-17-2010, 05:29 AM
The dam generates a low pressure area just behind itself which gives the air that has passed thru the radiator and engine compartment a place to exit. Removing the dam just forces the fan clutch to work harder because it now has to push the air thru the engine compartment. I would guess that certain air flow conditions around the truck would impact this even more like strong crosswinds and so on.
If you study the design a little on this vehicle (and most others) you will notice the front end kind of scoops and funnels air into the front of the truck across the heat exchangers (trans cooler, radiator et.) then it passes thru the engine compartment and must exit down and out the bottom of the truck. The dam causes a low pressure area which help evacuate this air which has now collected a lot of heat. While running at speed on the road all this air flow happens without much help. When you slow down or stop the fan must do all the work. Removing the dam just makes the truck think it is not moving and puts the load on the fan.
my $.02
mowdoc
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
