Using 0-30w oil in a diesel? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-26-2010, 05:53 PM Thread Starter
One thing I don't like about this new engine, is the idea of using 0-30w oil. It will result in slightly less friction and better mileage, but I would think the better mileage would come at the cost of engine life because the thinner oil can't provide the same "cushion" of protection that a thicker oil would. This isn't based on first hand knowledge or experience, but makes sense to me. Thicker oils are also approved and I think that's what I'll use when I get one of these some day. Anyone know more about this?
DirtBikePilot is offline
post #2 of 12 Old 03-26-2010, 06:32 PM
JK23112's Avatar
That viscosity of oil sounds way too thin to me - unless you reside in Alaska.
I've been driving diesel trucks (at work - not my own vehicle) for almost twenty years now, and every one of them has called for "15w-40" motor oil. They run so darn hot that it seems to me that the thin stuff would not be ideal for a compression-ignition engine. Then again, perhaps technology has moved forward a bit. Follow what it says in the owner's guide for the type/weight of motor oil, and then change it (and the oil filter) far more frequently than what they tell you.
FYI: I drove a 2008 Kenworth T-300 today (a rental truck) with a Paccar/Cummins 8.3L turbodiesel and it called for 15w-40 oil, as per a decal on the coolant reservoir. Nice truck!
~ Trucker by trade ~
2008 Sterling Acterra 3-axle straight truck (240-hp Cummins ISC)
2006 International 8600 tractor (350-hp Cummins ISM)
"If I passed you on the right, you're in the wrong lane!"
JK23112 is offline
post #3 of 12 Old 03-26-2010, 07:00 PM
The last number in the weight is the equivalent weight, so it is 30 weight. The "0" is for cold pour. Lighter weight oils remove heat faster than heavier oils. Do what the book says,,,,,,,,,,,,,,,,,,,,,,
Aussiekeeper is offline
post #4 of 12 Old 03-27-2010, 09:48 AM
s8v4o's Avatar
0-30w oil is ONLY used for ever increasing EPA restrictions due to "pollution" and NOT because that's what the motor needs. I would use a thicker oil. Especially if you are towing and live in a warmer climate. Ford is doing this to almost all of their vehicles.
s8v4o is offline
post #5 of 12 Old 03-27-2010, 09:52 AM
Not so much. The new oils are better lubricants and they transfer heat better. Thick oil is old school........................
post #6 of 12 Old 03-27-2010, 12:01 PM Thread Starter
Aussie- I would like to see your source for that information. I'm not disagreeing; I just want to learn more about this.
post #7 of 12 Old 03-27-2010, 02:23 PM
Rutcutter's Avatar
Not sure where you heard this as I just read the manual on the 6.7 and it said either 10-30 or 15-40..
16' F350 6.7L
White Platinum
Lariat Ultimate Pkg.
Warn GenII winch mount
Smitty Built 12k winch
2"Leveling kit
Dual Rancho steering Stabilizers
Toyo 35/12.50/20's MT's
11 SD F350 6.7L(SOLD)
08 F250 4x4 (SOLD)
06 F250 FX4 (Traded)
Pics
Rutcutter is offline
post #8 of 12 Old 03-27-2010, 07:16 PM Thread Starter
Oh, where did you find the manual? I read that "coffee table" book posted on TDS site, and it lists the oils approved for use in the 6.7. It's also listed here in the fourth line down on the first post: specs are up on the ford repair site - Powerstroke Nation
post #9 of 12 Old 03-28-2010, 06:50 AM
Powerstroke Techie
Some stuff should remain as proprietary information, like the coffee table books.
It bases oil use on TEMPERATURE.
You need 0w30 when it's super cold out.
Page 82 of the coffee table book that everyone is holding to gospel has this info in it, so does the diesel owner's supplement.
It would interest you to know, the 6.7 equipped trucks come with a block heater, but no cord, regardless of destination.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #10 of 12 Old 03-28-2010, 06:56 AM
Cutty72's Avatar
Quoted: 11 Post(s)
So does that mean you still need to buy the $75 block heater option, or you think there will be a cheaper price for the cord?
'01 F250 Lariat Crew Shortbed
Tunes by Swamps
4" Turbo back MBRP w/ muffler
GTP38R
6637 intake
3662 Maintenance Company Supply NCO
Cutty72 is offline
