Currently getting trained on the 6.7 at the Charlotte Training center - Ford Powerstroke Diesel Forum
post #1 of 47 Old 03-16-2010, 01:46 PM Thread Starter
Powerstroke Techie
I've got 2 days down, tomorrow is my last day of training on the new 6.7. It sure is an interesting motor. It looks packed under the hood, but with the quick removal of say the intake air tube, you can put your hand on the majority of the engine. Engine does have 2 separate cooling systems. 4 Thermostats, 2 radiators, 2 reservoirs practically everything is liquid cooled. The Diesel Exhaust Fluid is 32% Amonia and 68% Water. I suppose you could pee in the DEF tank and the engine would run on it.
If anyone has any questions, i'll see if I can answer them.
They really made this engine A LOT simpler, imo.
5 Year Ford Certified Diesel Master Technician
Specializing in: 6.0, 6.4, 6.7, and 7.3 Powerstroke Diesel
Currently Employed as a Diesel Technician for the
Walt Disney World Resort in Orlando, FL.
Specializing in: Detroit/Cummins/International
DieselDano is offline
post #2 of 47 Old 03-16-2010, 01:51 PM Thread Starter
Powerstroke Techie
Oh, and lets see, the regular version of the truck has a wastegate and no more hydroboost. It's got a vacuum assisted brake booster.
post #3 of 47 Old 03-16-2010, 02:13 PM
Big K's Avatar
Naa, there are sensors for contamination, it will set those off ASAP!!!!
Kevin "Big K" Neal
President
North Texas Power Stroke Association
972-768-7252
Big K is offline
post #4 of 47 Old 03-16-2010, 02:16 PM
no-tel-in's Avatar
Sweet! keep us posted
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #5 of 47 Old 03-16-2010, 02:30 PM
scotty2280's Avatar
did you see anything you didnt like?
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #6 of 47 Old 03-16-2010, 03:40 PM
have you heard anything along the lines of fuel mileage? i sure hope this motor becomes another 7.3L i might actually think about a Ford for my next truck then.
2008 Dodge Ram 3500 6.7L Cummins
Just here to advance my knowledge about diesels in general.
4X4livn is offline
post #7 of 47 Old 03-16-2010, 04:16 PM Thread Starter
Powerstroke Techie
Well, the PCM doesnt know what is in the tank. What it does look for is if there is a change in the emissions when the DEF is injected. If you were to say put water in the tank, it would see that it is causing no change when it is injected into the exhaust. And it will set a message on the instrument cluster saying that the DEF is contaminated. The DEF smells exactly like cat pee.
post #8 of 47 Old 03-16-2010, 04:18 PM
M4K3H808's Avatar
can you take pics? what would need cab off to work on the motor?
Ford Powerstroke 7.3l
K&N Intake
33x12.50 Mickey Thompson ATZ
6 speed manual transmition
Hawaii born and raised
M4K3H808 is offline
post #9 of 47 Old 03-16-2010, 04:21 PM Thread Starter
Powerstroke Techie
We were told that there was a group of engineers that drove something like 7 different trucks from a point A to point B and a dually with a thousand lb payload made 32mpg. That was the best of all the trucks though, so who knows.
Everythign on the engine seems very simple. Except for the cooling system ofcourse, but it seems like they did a LOT of trial and error to make it work. The upper intake takes like 12 bolts to get off, and the lower intake is another 8 or so. The high pressure fuel pump is in plane view in the center of the engine in the valley, its not 'inside' the motor.
post #10 of 47 Old 03-16-2010, 04:23 PM
M4K3H808's Avatar
wow so most work could be done on the motor with cab on?
K&N Intake
M4K3H808 is offline
