So I'm sure this wont be my last post in the next few weeks...... (sorry in advance and thanks for your patience) Just got the truck yesterday and while driving today I'm noticing a clunking noise only when making turns. (Have PRO COMP front end stabilizers.) If I sway back and forth with the steering wheel it wont make the noise but going slow(er) and making a sharp turn I'll notice it both turning left and right....
May be the front axle u-joints. Since you have no info on truck configuration, I will assume it is 4x4. One or both of the hubs my be stuck locked. It happens. I would check both axle shafts at the knuckle. Just turn the front drive shaft and see if one side doesn't turn freely. If so, then shove a long screwdriver in the u-joint on the side that does turn, to keep it from doing so, and try again. If the other side won't rotate, then your hub is locked on that side.
Made sure hubs are in auto this morning, turned them a few times to make sure and they are in the auto position.... doesn't sound like 4wd locking (partial) I've experienced that with my Jeep and it really grabs and is hard to turn (jeep) when it happened.....
It's been reported that the AdvancTrac causes this to happen. Try holding the button for 7 seconds, watch the dash for a message something like ADVTRAC OFF. Test drive to see if the condition still presents. It has something to do with how the system wants to control the wheel speed as if you are in a lost control situation.
Mine dose the exact same thing. It will only do it if I take a corner and hit a bump. Doesn't do it really at slow speeds more like when I'm turning off the highway ont a side street and hit a pot hole. It does kinda sound like when the abs kicks in. I'll turn off the nanny and see if it still does it.
Ok, even though my body bushings were wore out and replaced, I now have a distinctive front end thud.
I had my coolant flushed last week and asked them to check the front end. They said everything was tight and it may be the new body bushings settling it.
My body bushings are totally shot and had my friend look at the underneath with me and the only other thing we can think of in my case is maybe the control arms are making the noise as it only makes the noise when I'm turning in either direction and seems to come from under my feet in the cab....
It's the only thing that feels loose and that I can make move with my hand.
The joints are able to be moved ~ 1/32-1/16" on each end.
Sent from my iPhone using Tapatalk
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
