Just got my 16 F350 4X4 in December. Was curious what others are getting MPG wise and Exhaust fluid distance? I'm avg 11 and that's pulling a 12' cargo trailer with very little load 50% of the time and no trailer the other 50%. I am getting about 3K on my EF before it pops up a reminder that its 500 to E.
Welcome to the ORG Spark. I would chime in with help if I knew but I'm an old 6.0 guy and my fuel is based on my foot, not towing. There will be some guys who can give you the answers but again welcome and enjoy the site.
I can't offer a comparison towing heavy, but my lifetime average calculated by Fuelly is 17.7 since I started using the app. I fueled up yesterday and got 19.4 on that tank (just commuting).
I've got a 2013 F250 King Ranch, all stock with the exception of an S&B CAI, and I am averaging about 17 mpg and around 350-450 miles between regens. Both of these have been improved since I began using the Archoil additives BTW.
11 mpg is probably right for a f350 dually pulling a cargo trailer. The problem you're likely running into is wind resistance.
As milage goes down, def usage goes up. More fuel burned, more exhaust to treat. Anywhere from 3-5k miles to a tank of DEF is about right.
As the truck breaks in, milage will increase some, most experience this. Not exponentially, but some.
Driving habits contribute the most to mpg, as well as speed, gearing, etc...
I get 13.5-14.5 in my unloaded f250 running 80 on the highway on 35s...and I honestly don't know how long I go without filling the DEF, I fill it up when the tank gets to 2/3 of the way full else the check engine light comes on (broken sender in tank). But I think I did 4000 miles to a tank once upon a time.
My 2016 250 LB CC 4x4 (3.55 rear) averages about 13.5 -15 with a mix of in town and highway empty, pulling my 5th wheel (16.5K) on level ground it gets 8.5 -9.
Never really tracked the DEF
In town my milage tanks...I'll get only 140 miles to a tank and I get about 9-10.5 mpg, if I am strictly in town.
The only way people are seeing 16-17 mpg out of these trucks are the ones that are STOCK, stock suspension stock tires stock everything, maybe deleted, and driving conservatively 65-70ish mph on the freeway with little headwind.
The only time I've seen 16.5 mpg in my rig is running 80 up I-35 for ten hours with a nice tailwind. That never seems to happen to me except in that one case. I was pleasantly surprised at each fuelup on that trip.
Being leveled and on 35's I'm fairly happy with my milage. It's a pickup with the aerodynamics of a brick...there's only so much you can do.
All my numbers are hand calc'd, and I too have 3.55s.
Being you are a 3.73, that'll help with pulling some but it'll also cost a little mpg as well. Again, as far as freeway milage, its all about the speeds, winds, and your wind resistance of your load (truck+trailer or unloaded truck).
Loaded with 15k doing 70-75 mph I can see anywhere from 5.5-8.5 again just depends on wind and terrain. If I do 65 I can see almost 10.
op, I have 4:30 gears and get 10mpg @63 mph towing a 16k lb 5th wheel, when I start getting close to 70mph the drop is to about 9mpg. empty on the highway @ 70mph I get just about 15.5mph, again I start going over and the mileage will drop.
Its not a Prius nor is the fuel sipper diesel used to be.
I have 3.55 gears. Best I've seen is 17mpg at 75 mph and 10 mpg at 70 mph towing a 5,000 lb. boat . Truck is a 2016 with 7,500 miles on it. Bone stock.
I have a 2015 f350 4wd dually and end up averaging about 11. That is towing a fifth wheel probably half the time. I don't know the mileage on my DEF but it seems frequent--in line with your numbers.
I have a 2016 F350 CCLB Platinum with 3:55's and bone stock. Best I've seen is 18.7 mpg and that was around 60 mph for 300 miles. This is hand figured not the liar meter in the truck.
Average 13-14 around town and around 17 on the highway. 2013 F350 CCSB deleted, CAI w/ 35's and 3in.... 3.55 gears.... strong wind will kill those numbers quickly tho
Im getting about 18mpg highway, 13mpg city, 16.5 combination, 12mpg while towing 5,000 pounds. DEF fillup after 5,000 miles. The truck has 14k miles on the odometer. Everything is stock.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
