Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > General 6.4L Discussion
Old 06-21-2009, 01:54 AM
got ford got ford is offline
cleaning exhaust filter
How often should an 08 6.4l go into regen mode while traveling 60mph not hauling?
Old 06-21-2009, 05:41 AM
Greenhorn Diesel Greenhorn Diesel is offline
Each truck is different. Mine used to to it about once a tank full empty, and up to 4 times a tank full towing. But for some reason it doesn't go into regen anymore
Old 06-21-2009, 11:56 AM
W9GBB W9GBB is offline
Mine also did it about once a tank full. Was averaging about 14.5 MPG which is up 1 MPG since the Ford software update.
But somthing happened a week or so ago and it doesn't do it anymore either
Old 06-21-2009, 08:46 PM
Tick ST Tick ST is offline
My truck has 2160 ml on it, it has gone in to regen 9 times, some times for 10 to 15 min. I pulled trailer 300 mil out of the 2160. I dont know if this is ok or not. My buddy has a duramax and it did regen at 30000 mil the first time. I know maxs are dif but I am concerned.
Old 06-21-2009, 08:50 PM
Was the software update a recall or just somthing the dealer did for you to solve a problem?
Old 06-21-2009, 09:01 PM
Dieseltorkin Dieseltorkin is offline
Send a message via Yahoo to Dieseltorkin
Mine used to regen every 45 min on a trip while pulling. It no longer does it at all now that its Spartanized! lol
Old 06-21-2009, 09:30 PM
Did you chip it? How many mil on your rig? Dont know much about chips, kind of interested in doing somthing........
Old 06-21-2009, 09:37 PM
younggun55 younggun55 is offline
Send a message via AIM to younggun55
Delete pipe and Spartan tunes, your truck will never regenerate again
Old 06-21-2009, 09:38 PM
Yes, Spartan is a chip of sorts, it reprograms your pcm(computer) with custom tunes written for your vehicle. They also can Disable the regen and EGR on the 6.4's. You can get a DPF filter on tune or delete it which is what i would reccomend. For the tuner and dpf/cat delete your looking at around $1400. Should you need to go in for warrenty work you have to return it to stock first unless your dealer is mod friendly. Some of our site sponsors can hook you up with a package deal, Look at Cobbs performance, Spartan etc... in our sponsors colum.
Old 06-21-2009, 09:42 PM
What if you need warranty work done?
