I'm getting ready to install a viair compressor on my truck. The paperwork with the kit says that the compressors are moisture resistant but not waterproof. I have no plans to submerge into water, but my question is where have ya'll mounted them ? The reason I ask is would rain water be too much because I wanted to put it under the bed on the chassis but not sure about the moisture. My second choice will be in my toolbox.
I'm thinking about putting it where my spare used to be.. a bridge between the frame rails, and attaching it to that would work nicely.
What are your intentions for it? If for inflation (not horns) I highly rec a five gallon holding tank at a minimum... It'll compress, but it's slow going for a tire.
Yeah I have a 5 gallon tank. I'm not going with horns. It'll be for tires,beach balls,floats, etc. i was thinking that tank and comp in toolbox would take up a lot of real estate but I dont want to ruin the compressor by getting too wet.
Just an fyi, the mechanism on those things are pretty stout, and getting wet wouldn't be an issue so long as it isn't submerged.. I'm pretty impressed with mine. I run on the beach, and dropping pressure before and raising it afterward is nice to have. Just so long as nobody notices. Of somebody notices, they form a line..
I have mine on a piece of scrap steel above my rear axle. Mounted two five gallon tanks on either side and the compressor in the middle. Then again, I don't have a B&W Turnover Ball.
You'll be fine under the bed on the chassis. I had my ViAir mounted to the side frame rail for a while before relocating it to the spare tire location. Still working great after 9 years.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
