I've been reading forums for over a week now, looking for a resolution to a problem Im having with an 08 F250, XL, but no luck.
I am getting a Driver door Ajar warning on the dash.
I have the interior gutted looking for the problem.
I checked the switch at the latch. It electrically opens and closes when I press/release the button.
I have a good ground on the black wire at the switch. The other wire is Green with black tracer, and seems to be open. At least when I ohm it to ground it reads open, and no voltage on it when the truck is running. I'm not sure what should be on it though.
I traced it back to where it goes through the door into the chassis. The pin that connects to green/blk wire is pushed in at the connector on the chassis side. I'm pretty sure that is the issue. I tried to pull the pin out, but still not working. I tried to pull it apart inside the cab but the emergency brake mechanism is in the way. I'd like to jumper around the connector, but I have no idea where the wire goes from there. Does anybody know which module it goes to and/or path? Wiring diagram or pin out information would be helpful.
I appreciate any assistance.
