I've seemed to develop an engine tap you can hear changes with revs. Truck has 109k on it, dpf and egr delete, new oil change. 5w40 rotella t6 every 5k and fuel filters every 10k. What do you guys think, rocker arms or something else?
Could be a number of things... Any metal on the drain plug or in the filter? Can you get a vid from right above the motor?? 2 things come to mind are rockers or lifter problem. Does it sound more like an injector tick or a metal on metal like a lifter starting to go out?
No metal on drain plug. I have about 200 miles on the oil change. The truck runs fine and temps are right where they should be. No popping from the intake like the typical rocker arm symptoms. Noise seems to be isolated to the right side of the engine mainly, here's a better video at operating temp:
Yeah it's somewhat hard for me to tell. I did an oil change with 15w40 motorcraft about 870 miles ago and it made the noise a lot louder. I could even hear it out the exhaust, sounded like an exhaust leak a bit. Changed the oil, no metal on the drain plug, put my usual 5w40 t6 back in and now we're here about 200 miles in on the change.
Dropped it off at the dealer today. Luckily I still have a power train warranty. The weird thing is the truck drives fine so I don't think I dropped a cylinder. Idles fine and pulls hard. It may seem far fetched but do you think it may be a belt tensioner?
Yeah I will. I have the older style hoses. I'm at 109, I'm surprised they've held on for so long.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
