I have a 2008 f350 with 138k on the clock. the truck had a wet(damp) driver side frame rail in the wheel opening for a bit..... now when I first start the truck the steering wheel will not move and the brake peddle is hard as a rock with no brakes. after warming up the steering and brakes come back but there is a noticeable whine during steering and the brakes are weak and fade---- a large spot has also formed in the driveway and low on fluid..... I am assuming booster pump? is this a dealer mechanic deal or backyard mechanic fix? thanks
