Note to self, don't be lazy and let the fools at Jiffy Lube change your fuel
filter. I went to Jiffy Lube last night because I needed an Oil and Fuel filter
change. I had my own filters, but I didn't feel like doing the work because of
the sub-zero temps here in Virginia.
Well guess what happened? The jokers at Jiffy Lube changed the fuel filters
and then decided to start the truck without cycling the fuel pump 6x for 30sec.
Now the fuel system has air in it and the truck won't start. ARGH!!!!!!!
Now I've got to get it towed to a shop that can bleed the fuel system. Likely
it'll cost me $200. $100 for tow and $100 for the labor charge. Blah!!!!
