P0128 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-15-2014, 06:21 PM Thread Starter
Sam Hain's Avatar
P0128
Got check engine light on way home, code showed P0128. Looked it up an it said coolant below operating temp. Do I have a thermostat hung open?
Sam Hain is offline
post #2 of 11 Old 04-16-2014, 05:28 AM Thread Starter
Sam Hain's Avatar
Found this on dieselsite
Another emissions regulation requires the monitoring of engine temperature and the amount of time it takes the engine to reach full operating temperature. Over the winter months we had seen a lot of check engine light concerns with the DTC's P0128 & P0196 both of which are directly related to engine temperature and warm up. P0128 is for coolant and P0196 is for engine oil temperature which is also affected by cooling system concerns.
The last we heard what that Ford Engineering is investigating this concern so I would guess that a service bulletin or a Field Service Action will be issued in the future to address this problem.
Now, to explain this, if the cooling system has a problem, whether it be low coolant, a stuck or leaking thermostat or a problem with the ECT or EOT sensors one or both of these codes will set and the Check Engine light will illuminate. There have been some instances of faulty thermostats but not an epidemic. I personally pulled one out of a truck that was bent believe it or not. The real issue is in cold weather and cold geographic locations where trucks are started and allowed to sit idling. Never a good idea to idle your truck more than a few minutes anyway. In discussing this with other technicians and comparing freeze frame data, if the engine temperature does not reach 170 degrees-F in 10 minutes the code will set. The use of a block heater seems to aggravate this as well.
What the actual problem is and what the "fix" will be is anyone's guess. The parameters are not changeable so I imagine a combination of reduced cold idling and getting the engine warm up faster will be the challenge. It also doesn't help that that the cooling fan seems to be moving a lot of air when cold...
__________________
Ford Master Diesel Technician
Diesel Technician Society
Diesel Mentor Directory
Sam Hain is offline
post #3 of 11 Old 04-16-2014, 05:30 AM Thread Starter
Sam Hain's Avatar
Not real sure why this happened, it was about 45 here yesterday. I had been driving the truck at city speeds for probably 20mins. Stop and go traffic, up to 60mph. I was running 60mph when the check engine light came on. I drove another 20mins home and pulled the code. Cleared it and started truck, everything seemed fine. I checked the coolant and its right below the max line so I'm not sure what happened.
Sam Hain is offline
post #4 of 11 Old 04-16-2014, 07:31 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
What temperature did the coolant get up to? If it doesn't get into the 190's it could be a thermostat.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 11 Old 04-16-2014, 07:34 AM Thread Starter
Sam Hain's Avatar
IDK, I don't have any type of aftermarket guages. The one on the dash was almost half way between cold and hot. I know thats not much help. The odd thing was I'd been driving for 20mins and it wasn't really cold outside. I went ahead and ordered new t-stats from rock auto so I'll try to change them next week.
Sam Hain is offline
post #6 of 11 Old 04-16-2014, 07:37 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I bet new thermostats will solve your problem
08 F350 cc/sb 4X4
post #7 of 11 Old 04-16-2014, 07:40 AM
Gotta get a monitor in there and see what coolant temps are. If you wanna do a monitor on the cheap, get a Bluetooth OBD adapter and the app Torque for your phone. Pretty cheap way to have a basic monitoring system.
2008 F350 RCLB, 2011 bed and wheels
SCT tuned, 4" straight pipe exhaust
Sideswipe505 is offline
post #8 of 11 Old 04-16-2014, 07:55 AM Thread Starter
Sam Hain's Avatar
I have a motorola razr (android) phone.
will this work? http://www.amazon.com/Vgate-ELM327-Bluetooth-Scanner-ANDROID/dp/B00AAOOQJC/ref=sr_1_4?ie=UTF8&qid=1397659959&sr=8-4&keywords=bluetooth+obd+adapter
also, do I need the pro or lite version of torque?
thanks,
Sam Hain is offline
post #9 of 11 Old 04-16-2014, 08:12 AM Thread Starter
Sam Hain's Avatar
I ended up getting this one http://www.amazon.com/BAFX-Products-Bluetooth-diagnostics-Android/dp/B005NLQAHS/ref=sr_1_1?ie=UTF8&qid=1397661057&sr=8-1&keywords=bluetooth+obd+adapter
Sam Hain is offline
post #10 of 11 Old 04-16-2014, 09:52 AM
I never used the lite version. I spent the $5 on it. Be aware that there are certain things Torque won't monitor but it's a good skeleton system til you can afford a real monitor. That's what I'm doing til I can afford an edge.
