another question about EGR DPF tuner stuff - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Rocweiller
post #1 of 4 Old 04-14-2014, 10:07 AM Thread Starter
So as asked before if i could do the egr and tuner then do the DPF delete like the following weekend and the consenses seems I could possibley clog up the DPF while it is still in without the REGEN option. SO here is my new question
can i do it in reverse...do the Full exhaust and program the tuner to turn off the EGR and DPF then do the egr delete like the following weekend? I know there is still a chance of the egr causing issues but just trying to do the mods in phases due to time and winding conditions we have going on here
DONE:
EGR delete--4" turbo back exhaust
75HP tune
hotairgypsy is offline
post #2 of 4 Old 04-14-2014, 10:51 AM
This is all covered in the sticky, but yes. You can turn the EGR off from some tuners manually while it's still in place then remove it later.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #3 of 4 Old 04-14-2014, 11:09 AM
Rocweiller's Avatar
Quoted: 2 Post(s)
Egr delete can come later. Spartan you can turn it off with ill dpf deleted tunes.
STANGMAN893 likes this.
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
post #4 of 4 Old 04-14-2014, 11:24 AM
JSBucinski's Avatar
First i would like to know what tuner you have. Some tuners do it automatically and some tuners you have to tell it to turn off the EGR. Now if your question of "can" is about reliability, Yes. I have had the dpf delete and tuner for about a year with the EGR turned off. Just havent had the time to install it (except now im done with recruiting and will be doing all that and more now that i have my life back). I have had no problems with the system. I still reccomend taking it off because coolant will still flow and if it cracks it dumps it right into your heads, which is bad, very bad. I agree with your method of one mod at a time. That way you can run it for a bit, if a problems shows itself you know what mod that you recently did caused it.
SSgt. Bucinski USMC
2008 Ford F250
6.4 Powerstroke Turbo Diesel
"My reputation precedes me."
JSBucinski is offline
