Debating upgrading from a 7.3 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-13-2014, 03:21 PM Thread Starter
Rosco P Coltrain's Avatar
Quoted: 2 Post(s)
I found a 6.4 2008 450 with 88,000 miles I like and I'm debating upgrading from my e99 7.3. I have 303xxx miles on mine and the engine is running well. (no engine work except for glow plugs ever btw). I either want to put some money in mine ( go fast parts and tranny swap) or upgrade. I need to do some rear end work and replace the hub bearing assembly in mine. (a lot of minor stuff)
Heres the link.2008 FORD F-450 For Sale in Mandan North Dakota | Bill Barth Automotive Group Just would like to get some input.
Sold
Black Beauty
E99 F-250 302xxx miles
Original everything on motor
Pulls it goin 65 MPH
Extra Leaf Springs, 5 inch strait pipe, 6637 air
The New Black Mistress
Pulls it goin 90 MPH
Air bags, ARB locker and compressor
Rosco P Coltrain is offline
post #2 of 6 Old 04-13-2014, 05:55 PM
Looks like you could use a 450 judging by the sig pic! One thing to keep in mind is I'd expect about 10 mpg in that 450 and maybe after you do the deletes 13mpg. Check carfax and oisis report . If everything checks out upgrade!
Tjmaxx is offline
post #3 of 6 Old 04-14-2014, 12:04 PM
JSBucinski's Avatar
I love love love my 6.4. With that being said i have a few questions about your 7.3. How bad is the rust and wear and tear on everything but the engine. With 300k that could go either way. I would be hesitant to spend a lot of money on a vehicle with 300k miles. Sounds like you have a very sturdy truck though and you could add to that with a little money. Seeing how thats something i hear from all your 7.3 guys and that you love very much. If you get that 6.4 you have to delete the egr and dpf to start (which includes tuner) and also if you are serious do a fuel filter system and coolant filer. Then maybe you are sitting in the same ballpark as your 7.3. I would def do your reports on this truck. What has been repalced will tell you a lot. Did the truck have a problem with fuel in the oil (bad for everything), did it loose its front cover at some point. You may get lucky like me and find one that didnt have anything done to it except the Ford upgrades that came out.
SSgt. Bucinski USMC
2008 Ford F250
6.4 Powerstroke Turbo Diesel
"My reputation precedes me."
JSBucinski is offline
post #4 of 6 Old 04-15-2014, 05:20 PM Thread Starter
Quoted: 2 Post(s)
Thanks Sargent,
I only have light surface rust on the bottom that was going to sand out and rhino line otherwise only light scratches. How much does that cost to do the deletes, tuner, and fuel system? Ballpark 3 grand?
-Ross
Sold
Black Beauty
post #5 of 6 Old 04-15-2014, 07:28 PM
Depends on what route you take in tuner dept. you could spend 500ish on a dpf-r or you could spend 2k on a H&S then there's others that fall in the middle. I'd say with out labor your looking at 3-4k on deletes with a low pressure fuel system pump.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #6 of 6 Old 04-16-2014, 09:54 AM
JSBucinski's Avatar
You are looking at anywhere from 3-4grand for doing it right.
I would highly reccomend checking out the general 6.4 mods in the sticky.
Here is the order i would rec.
1.) Tuner and DPF delete.
2.) EGR delete > egr block off plates.
( I consider these two mandatory if you want it to last, and live some where you dont have to have it inspected.)
3.) Airdog (or otehr fuel system)
4.) Coolant Filter
5.) Head studs, i only put this one down here because you have to remove the cab most times to do it. Some people can do it without. If something comes up where the cab comes off do it then. Or if you plan on having a lead foot it might want to happen sooner.
SSgt. Bucinski USMC
2008 Ford F250
